Hello again. I am trying to put together my own routine to see if I know what I am doing. Just a short routine.
(DEFUN C:enddwg ()
(COMMAND "-purge" "a" "" "N") ;PURGE ALL PARTS OF THE DRAWING
(COMMAND ".MV" "L" "ON" "ALL" "") ;LOCK VIEW PORTS
(COMMAND "QSAVE") ;SAVE DRAWING
(COMMAND "QUIT") ;QUIT DRAWING
) ; end defun
(PRINC)
(princ "\n enddwg.lsp is loaded. Type \"ENDDWG\" to run.")
(princ)
I am not locking the viewports. I would also like to know how to turn off the viewport(s) and then save and quit
Any suggestions?
HD
Solved by hmsilva. Go to Solution.
(COMMAND ".MVIEW" "L" "ON" "ALL" "")
MV it's an Alias for the MVIEW command...
To turn OFF the viewport(s), try
(COMMAND ".MVIEW" "OFF" "ALL" "")
Henrique
Thank you for the assistance. What you provided worked, but I wasn't thinking when I requested turning off the VPort. I need to freeze it. Everything you provided worked exactly correct. I already know the last part, and will get it taken care of tomorrow. Again, thank you.
HD
