Visual LISP, AutoLISP and General Customization
Have hit a trouble spot with a short time saving Routine.
9 REPLIES 9
Message 1 of 10
HullDrafter
504 Views, 9 Replies
I am in the process of writing a small program to go in, delete 4 layers that aren't needed. Then using a command that is in another package of commands that end with .FAS, I will use this command to select everything, and turn it all gray (COLOR:252). The first part works perfectly.
(command ".laydel" "n" "s-grid" "n" "a-anno-dims" "n" "a-anno-symb" "n" "a-detl-genf" "" "y")
The second part. Accessing the command that is now part of my start-up. Doesn't happen. I can type the command in right after I run my LISP, and it works. But, inside my lisp, it doesn't. I've tried with command "cln", "_cln" and "-cln". Nothing seems to work.
Any suggestions?
HD
9 REPLIES 9
Message 2 of 10
phanaem
in reply to: HullDrafter
Try (C:CLN)
Message 3 of 10
HullDrafter
in reply to: phanaem
Sorry, that didn't work. I do appreciate that one though. I hadn't thought of it.
Message 4 of 10
HullDrafter
This is what I got;
Command: ; error: bad argument type: stringp nil
HD
Message 5 of 10
phanaem
@HullDrafter wrote:
This is what I got;
HD
It looks like an error in lisp, after routine started.
This is the same error you had before, when you tried (command "cln")?
Message 6 of 10
HullDrafter
Short story. As Cln is not an autocad command, a coworker had to show me where they got it from. I loaded it into my startup so I now have it. I wrote the lisp routine to remove 4 layers and everything on them, as they are always the same four layers. Cln works. I type the command,  tell it 252 for a color change, hit enter. It grabs everything, including blocks, changes it all to gray (color:252). I am trying to set up the block to do everything. Open drawing, activate LISP, saveas, move onto the next background drawing. Outside the Lisp routine, Cln works fine. Inside, no go.
HD
Message 7 of 10
hmsilva
You can try to provide the cln function the prompt answers...
Perhaps something like this:
(vl-load-com);; Loads Visual LISP extensions to AutoLISP
(vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) "cln all\r color\r 252\r")
Is just an example, I don't know the cln function prompts.
HTH
Henrique
Message 8 of 10
bhull1985
in reply to: hmsilva
Yes exactly.
The problem you're having is because it's tough to call a lisp function while currently running a lisp function, unless it's a subfunction.
The "C:CLN" , specifically the "C:" portion means that you're not using a sub...the (vla-sendcommand) is the method I used to accomplish a similar task, calling one routine while in the middle of another routine.
Here's a snippet from my .lsp
(vla-sendcommand doc (strcat "horiz" " " "ALL" " " " "))
 Where the horiz is defined as the following:
(defun C:HORIZ	 (/ ss)
  (if (setq ss (ssget '((0 . "INSERT"))))
    (foreach obj  (ssvla ss)
      (foreach att  (vlax-safearray->list
		      (vlax-variant-value (vla-getattributes obj)))
	(vla-put-rotation att 0.0))))
  (princ)
);horiz defun
 So you can see here how the (vla-sendcommand) works for a C: function. The (strcat) is absolutely necessary if more than the call to the function is required (i.e. user input).
And yes, you will need to obtain a pointer to the active document for sendcommand to work.
That's the (vlax-get-acad-object) nested statement, usually sets activedoc to a variable. Include all of that in your routine, have the sendcommand have your pointer as the argument (mine is using  "doc" in the example above), and it should work for your purposes.
HTH
Please use code tags and credit where credit is due. Accept as solution, if solved. Let's keep it trim people!
Message 9 of 10
hmsilva
in reply to: bhull1985
Brandon, really? Smiley Wink
Try
(vla-sendcommand doc "horiz\rALL\r\r")
or even
(vla-sendcommand doc "horiz ALL  ")
Cheers
Henrique
Message 10 of 10
HullDrafter
With everybody's help, got it to work most of the way through. Thank you all.
”Boost
