Visual LISP, AutoLISP and General Customization
Hatch lisp
7 REPLIES 7
Message 1 of 8
john-B
3033 Views, 7 Replies
Hatch lisp
Hi all,
I am trying to write a lisp routine that will make a layer called hatch, set it as current and then run the hatch command.
BUT the hatch command is not bring up the hatch dialogue box, it just puts things on the command line.
The layer is being made & set current.
The lisp is as follows:
(defun c:hh (/ ec)
(setq ec (getvar "cmdecho"))
(setvar "cmdecho" 0)
(command "-layer" "m" "hatch" "c" "8" "" "l" "continuous" "" "s" "hatch" "")
(command "hatch")
(setvar "cmdecho" ec)
Any help would be appreciated.
On another matter, I have just found the bevel lisp routine by Terry Miller which works great BUT only for imperial measurements. I would like to know if anyone knows of a similar routine, or how to make Terry's metric, that will work for metric measurements.
Regards
JohnB
7 REPLIES 7
Message 2 of 8
Kent1Cooper
in reply to: john-B
Try:
(initdia)
(command "_.bhatch")
Kent Cooper, AIA
Message 3 of 8
Hallex
in reply to: john-B
If you want to create hatch without picking
the inner point and change  the hatch properties,
see -hatchedit command, e.g.:
(defun c:hh (/ cts ec ent)
(setq cts (ssget ":S"    (list      (cons -4 "<or") (cons -4 "<and")(cons 0 "lwpolyline")(cons 70 1)(cons -4 "and>")
  (cons 0 "circle")
    (cons -4 "or>")))); <-- chage filter to suit
(setq ent (ssname cts 0))      (command "_.-hatch" "_p" "_solid" "_s" ent "" "")
(command "_.-hatchedit" "_l" "" "_p" "ansi32" "0.25" "90")
(princ)
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 4 of 8
john-B
in reply to: Kent1Cooper
Thanks Kent.
I thought I had tried all the combinations of _ - . hatch & bhatch must have missed that one.
Perfect!!!!
Message 5 of 8
scot-65
in reply to: john-B
OK, now for your next challenge:
In lieu of setting to another layer without user knowledge, and
leaving him on that layer when finished, one can use the
CHPROP "Last" option to direct the newly created object to
the desired layer and everyone will be happy.
This will involve the following:
(if not TBLSEARCH "Layer"
   create layer
   thaw or turn on layer
);if
ENTMOD, and SSGET "Last",
or just use CHPROP for these last two.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Message 6 of 8
john-B
in reply to: scot-65
Good thinking scott.
I have done that & it works perfectly.
JohnB
Message 7 of 8
john-B
in reply to: john-B
Scot,
Further to your suggestion for the hatch lisp, is there any way for this to happen with dimensions.
At the moment I have the macros set as follows:
^c^c-layer make dim colour 7;-colour bylayer^C^C_dimaligned
This works for placing the dimensions on the dim layer but it would be nice if it would
revert to the previous layer setting
Regards
JohnB
Message 8 of 8
sal.mardan
in reply to: john-B
where is lisp for hatch  i wand new hatch how save hatch
”Boost
