Visual LISP, AutoLISP and General Customization
Handle ID's
5 REPLIES 5
Redraiderr2009
1262 Views, 5 Replies
Handle ID's
Is there a way to give an object a new Handle ID number?
5 REPLIES 5
copy it and remove the source-object.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Yeah.... I meant more via programming. Well... hold on, maybe you are on to something. I will explore that idea a little more, it's a little roundabout, but that might work.
I want use match properties for hatch patterns, but since our notes are linked to the handle ID numbers of that hatch, a different hatch means it needs a differnt label. I get the area and other data via xdata. Match prop keeps the same handle number but assigns it a different pattern name. I need it to destroy the handle ID and give it a new one.
dgorsman
in reply to: Redraiderr2009
No, you can't assign an arbitrary handle to an object.
Alfred.NESWADBA
in reply to: dgorsman
Maybe not with LISP (I don't use LISP so my knowledge is very limited for that), but with dotNET or ARX you can. You can e.g. create a new line to get a new handle and then exchange the handle between any object and the handle of that line. Afterwards you can then delete the line.
- alfred -
Alfred NESWADBA
dgorsman
in reply to: Alfred.NESWADBA
Thats not assigning a new handle, its creating a copy of the object which AutoCAD then assigns a unique handle ID during the creation process.  Its not the original object, even if it has the same properties.  For example, you can't create a new line (even a copy) with handle ID "456AB" even if it's currently unassigned.
”Boost
