Could any one help me to create a code that let me adjust all lines direction to be in +X & +Y & +Z directions.
That mean all lines should have Start X & Y & Z equal or smaller than corresponding End X & Y & Z.
Here you are the concept and i wish any one can write code for it :
for any line in the model;
if Start X bigger than corresponding End X then; flip line, else; do nothing
if Start Y bigger than corresponding End Y then; flip line, else; do nothing
if Start Z bigger than corresponding End Z then; flip line, else; do nothing
Thanks in advance
(defun c:LineadjustXYZ ( / ss cnt 1e Spt Ept ) ; Command is adjustable.
(setq ss (ssget '((0 . "LINE"))))
(setq cnt 0)
(repeat (sslength ss)
(setq 1e (ssname ss cnt)
Spt (cdr (assoc 10 (entget 1e)))
Ept (cdr (assoc 11 (entget 1e)))
(if (or (> (car Spt) (car Ept))
(> (cadr Spt) (cadr Ept))
(> (caddr Spt) (caddr Ept))
(progn
(entmod (subst (cons 10 Ept) (assoc 10 (entget 1e)) (entget 1e)))
(entmod (subst (cons 11 Spt) (assoc 11 (entget 1e)) (entget 1e)))
(setq cnt (1+ cnt))
(princ)
Hi Tohami
You have to decide when you want to flip a line, because is not clear...
Those 3 conditions can meet all three together, any two at once, or just one of them....
And, except for the fist case, if you flip a line, then according to your rule, you must flip it again...
If you decide when to flip, you can use this code:
(defun flip_line (ent / p1 p2) ; ent is ENAME type
(setq ent (vlax-ename->vla-object ent)
p1 (vlax-get ent 'StartPoint)
p2 (vlax-get ent 'EndPoint))
(vlax-put ent 'StartPoint p2)
(vlax-put ent 'EndPoint p1)
I think you then need all these lines with no negative deltas in X, Y & Z, right?. I have this routine that put the lines in the first quadrant direction.
(defun f2 () (setq ss (ssget '((0 . "LINE") ))) (if (not ss) (exit)) (setq oldos (getvar "OSMODE")) (setvar "OSMODE" 0) (if ss (setq i (sslength ss))) (while (not (minusp (setq i (1- i)))) (setq 1e (ssname ss i) Spt (cdr (assoc 10 (entget 1e))) Ept (cdr (assoc 11 (entget 1e))) ang (angle Spt Ept) ) (cond ((and (> ang (/ pi 2.0)) (<= ang pi)) (command "._Mirror" 1e "" spt (polar spt (/ pi 2.0) 1.0) "_Y")(setq 1e (entlast))); 2nd Quad ((and (> ang pi) (< ang (/ (* 3.0 pi) 2.0))) (command "._Mirror" 1e "" spt (polar spt (/ (* pi 3.0) 4.0) 1.0) "_Y")(setq 1e (entlast))); 3rd Quad ((and (>= ang (/ (* 3.0 pi) 2.0)) (< ang (* pi 2.0))) (command "._Mirror" 1e "" spt (polar spt 0.0 1.0) "_Y")(setq 1e (entlast))); 4th Quad (T nil) ) ;; Now for Z values (setq oLine (vlax-ename->vla-object 1e)) (setq deltas (vlax-safearray->list (vlax-variant-value (vlax-get-property oLine 'Delta)))) (if (minusp (last deltas)) (progn (setq p1 (vlax-get oLine 'StartPoint) p2 (vlax-get oLine 'EndPoint)) (vlax-put oLine 'StartPoint p2) (vlax-put oLine 'EndPoint p1) ) ) ) (setvar "OSMODE" oldos) (princ) )
Hope this is what you need.
Justo Aguiar
