Visual LISP, AutoLISP and General Customization
HATCH COLOUR LISP ROUTINE
36 REPLIES 36
Message 1 of 37
4257 Views, 36 Replies
HI,
I am in need of a lisp routine which will automatically pick up all hatch and solid hatch patterns within a drawing and change the colour to colour 254.
Any help would be much appreciated.
Thank you
36 REPLIES 36
Message 2 of 37
chatsupakasem
;;; Change all HATCH objects color to 254
;;; DXF 62 Color number (fixed)
(defun c:hc (/ oldcmd)
(setq oldcmd (getvar "cmdecho"))
(setvar "cmdecho" 0)
(command "_.chprop"
(ssget "x" (list (cons 0 "HATCH")))
"Color"
254
(princ "\nChange all hatch objects color to 254.")
(setvar "cmdecho" oldcmd)
(princ)
Message 3 of 37
Thank you so much. It works great. Thank you
Message 4 of 37
CADD-Co
I'm impressed with that routine and have a similar question.
Could it be modified to select only hatch 'Angle' and change only those to 'ANSI31' and colour 254?
Any assistance appreciated. Cheers
Message 5 of 37
chatsupakasem
;;; Update OLDPATTERN to NEWPATTERN and Set color to NEWCOLOR.
;;; REPLACE VALUE OF OLDPATTERN, NEWPATTERN AND NEWCOLOR VARIABLES WHICH YOU WANT.
(defun c:H2 (/ newpattern oldpattern newcolor s ej a n)
(setq oldpattern
"ANGLE" ; OLD PATTERN NAME
newpattern
"ANSI31" ; NEW PATTERN NAME
newcolor 254 ; NEW COLOR
(if (setq s (ssget "x" (list (cons 0 "HATCH") (cons 2 oldpattern))))
(progn
(setq n (sslength s))
(while (setq ej (ssname s 0))
(entmod
(subst (cons 2 newpattern) (assoc 2 (setq a (entget ej))) a)
(command "_.chprop" ej "" "Color" newcolor "")
(ssdel ej s)
(princ "\nChange ")
(princ n)
(princ (strcat " " oldpattern " to " newpattern " Hatch.")
(princ (strcat "No " oldpattern " Hatch found!!!"))
(setvar "cmdecho" 1)
(princ)
Message 6 of 37
in reply to: chatsupakasem
Hi, in the first routine that you mentioned is it possible to change the hatch colour within the Block references or any DWG references?
Any assistance will be of great help.
Message 7 of 37
pbejse
Hatch of a specific pattern? to what color? Block modifcation affects all intances on a single drawing.
DWG references?
Are you refering to XREF?
Message 8 of 37
in reply to: pbejse
All Hatch patterns
Yes needed to reflect in all block references!
yes Xref's
Message 9 of 37
pbejse
(defun c:HC ( aDoc color)
(vl-load-com)
(setq aDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
  	(if (setq color (acad_colordlg 7 t))
	      (progn
		(vlax-for blk (vla-get-blocks aDoc)
		      (if (and
				(eq :vlax-false (vla-get-islayout blk))
				(eq :vlax-false (vla-get-isxref blk))
		                 (vlax-for itm blk
		                       (if (eq  (vla-get-ObjectName itm)
		                                 "AcDbHatch" )
		                             (vla-put-color itm color)
      (vla-regen adoc acActiveViewport)
      (princ)
Message 10 of 37
in reply to: pbejse
I get this error,
error: too few arguments
Do i need to load some variables, please let me know
Message 11 of 37
pbejse
oops.. my bad
(defun c:HC ( / aDoc color)
Message 12 of 37
I figured out "/" was missing in the defun line.
The lisp changes the colour of hatches in the blocks, but not the reference files, I mean the Xref , Any idea!
Message 13 of 37
pbejse
Listen, we can include xref objects by taking this line out
But i would advice against it.. XREF are so named and to be trated as such. a Reference drawing.
 Any modifications should be done on the drawing
Just my 2 cents
(if
		                 (vlax-for itm blk
		                                 "AcDbHatch" )
Message 14 of 37
cadheinz
in reply to: pbejse
Can we change that I can select a block in which I want to change the hatching
Thank you
Kann man das ändern das ich einen Block wählen kann bei dem ich die Schraffur ändern will
Danke
DH
Message 15 of 37
pbejse
in reply to: cadheinz
Thank you
Have you decided what to do with XREF objects?
Message 16 of 37
cadheinz
in reply to: pbejse
X-ref I do not want to choose just one block.
X-ref brauche ich nicht, will nur einen Block wählen können
DH
Message 17 of 37
in reply to: pbejse
Thanks its Working!
Message 18 of 37
pbejse
Quick mod
NO XREF on selection mode/ Option to process all BLOCKS/XREF
(defun c:HC (/ _Chatch blk obj aDoc color)
  (vl-load-com)
  (defun _Chatch (b c)
    (vlax-for itm b
	      "AcDbHatch"
	(vla-put-color itm c)
  (initget "A")
  (if (setq obj (entsel "\nSelect object to process/A for all: "))
    (progn
      (cond
	((listp obj)
	 (if (and
	       (eq "AcDbBlockReference"
		   (vla-get-ObjectName
		     (Setq blk (vlax-ename->vla-object (car obj)))
	       (not (vlax-property-available-p blk 'Path))
	       (setq blk
		      (vla-item	(vla-get-blocks aDoc)
				(vla-get-EffectiveName
				  blk
	   (_Chatch blk color)
	   (princ "\nObject Not a Block:")
	((eq obj "A")
	   (if (and
	     (_Chatch blk color)
     (if color  (vla-regen adoc acActiveViewport))
  (princ)
Command: hc
HTH
Message 19 of 37
cadheinz
in reply to: pbejse
Thank you 1000 times superSmiley Happy
1000 mal Danke   super
DH
Message 20 of 37
pbejse
@Anonymous wrote:
Thanks its Working!
I didnt realize there were two of you Smiley Very Happy
To both:
You are Welcome. Glad i could help
Cheers
”Boost
