Hi, in the first routine that you mentioned is it possible to change the hatch colour within the Block references or any DWG references?
Any assistance will be of great help.
@raghavendrabhat6624 wrote:Hi, in the first routine that you mentioned is it possible to change the hatch colour within the Block references or any DWG references?
Hatch of a specific pattern? to what color? Block modifcation affects all intances on a single drawing.
DWG references?
Are you refering to XREF?
All Hatch patterns
Yes needed to reflect in all block references!
yes Xref's
(defun c:HC ( aDoc color) (vl-load-com) (setq aDoc (vla-get-ActiveDocument (vlax-get-acad-object))) (if (setq color (acad_colordlg 7 t)) (progn (vlax-for blk (vla-get-blocks aDoc) (if (and (eq :vlax-false (vla-get-islayout blk)) (eq :vlax-false (vla-get-isxref blk)) ) (vlax-for itm blk (if (eq (vla-get-ObjectName itm) "AcDbHatch" ) (vla-put-color itm color) ) ) ) ) (vla-regen adoc acActiveViewport) ) ) (princ) )
I get this error,
error: too few arguments
Do i need to load some variables, please let me know
I figured out "/" was missing in the defun line.
The lisp changes the colour of hatches in the blocks, but not the reference files, I mean the Xref , Any idea!
@raghavendrabhat6624 wrote:I figured out "/" was missing in the defun line.
Listen, we can include xref objects by taking this line out
But i would advice against it.. XREF are so named and to be trated as such. a Reference drawing.
Any modifications should be done on the drawing
Just my 2 cents
(if (eq :vlax-false (vla-get-islayout blk)) (vlax-for itm blk (if (eq (vla-get-ObjectName itm) "AcDbHatch" ) (vla-put-color itm color) ) ) )
Can we change that I can select a block in which I want to change the hatching
Thank you
Kann man das ändern das ich einen Block wählen kann bei dem ich die Schraffur ändern will
Danke
@heinz.dober wrote:X-ref I do not want to choose just one block.
X-ref brauche ich nicht, will nur einen Block wählen können
Quick mod
NO XREF on selection mode/ Option to process all BLOCKS/XREF
(defun c:HC (/ _Chatch blk obj aDoc color) (vl-load-com) (defun _Chatch (b c) (vlax-for itm b (if (eq (vla-get-ObjectName itm) "AcDbHatch" ) (vla-put-color itm c) ) ) ) (setq aDoc (vla-get-ActiveDocument (vlax-get-acad-object))) (initget "A") (if (setq obj (entsel "\nSelect object to process/A for all: ")) (progn (cond ((listp obj) (if (and (eq "AcDbBlockReference" (vla-get-ObjectName (Setq blk (vlax-ename->vla-object (car obj))) ) ) (not (vlax-property-available-p blk 'Path)) (setq blk (vla-item (vla-get-blocks aDoc) (vla-get-EffectiveName blk ) ) ) (setq color (acad_colordlg 7 t)) ) (_Chatch blk color) (princ "\nObject Not a Block:") ) ) ((eq obj "A") (setq color (acad_colordlg 7 t)) (vlax-for blk (vla-get-blocks aDoc) (if (and (eq :vlax-false (vla-get-islayout blk)) (eq :vlax-false (vla-get-isxref blk)) ) (_Chatch blk color) ) ) ) ) (if color (vla-regen adoc acActiveViewport)) ) ) (princ) )
Command: hc
HTH
@heinz.dober wrote:Thank you 1000 times super
1000 mal Danke super
@raghavendrabhat6624 wrote:Thanks its Working!
I didnt realize there were two of you
To both:
You are Welcome. Glad i could help
Cheers
