Try this code and let me know how things get on with you .
(defun c:Marks (/ *error* cross o c l ss i) ;; --- Tharwat 09. May. 2013 ---;; (defun *error* (x) (if o (setvar 'osmode o) ) (if c (setvar 'cmdecho c) ) (princ "\n*Cancel*") ) (defun cross (pt l / a b c d) (entmakex (list (cons 0 "LINE") (cons 10 (setq a (trans (polar pt (/ pi 2.) (/ l 2)) 1 0))) (cons 11 (setq b (trans (polar pt (/ (* 3. pi) 2.) (/ l 2)) 1 0)) ) ) ) (entmakex (list (cons 0 "LINE") (cons 10 (setq c (trans (polar pt 0 (/ l 2)) 1 0))) (cons 11 (setq d (trans (polar pt pi (/ l 2)) 1 0))) ) ) ) (setq o (getvar 'osmode) c (getvar 'cmdecho) l (getvar 'dimcen) ) (mapcar 'setvar '(osmode cmdecho) (list 0 0)) (if (setq ss (ssget '((0 . "CIRCLE,ARC")))) (repeat (setq i (sslength ss)) (setq e (entget (ssname ss (setq i (1- i))))) (cross (cdr (assoc 10 e)) (* l 2.)) ) ) (*error* nil) (princ "\n Written by Tharwat Al Shoufi") (princ) )
@CheleCity wrote:It drew some tick marks on a random place on the screen, and they weren't grouped. Sorry
What do you mean by group ?
Upload a sample drawing showing your task before and after .
I mean the "Group" function. When you group something, when you select something one item in the group, it will select all of them.
There is no need to upload drawing. Center marks are common items. I would just like them to be grouped instead of individual lines, especially when you using negative dimcenter value. With negative dimcenter values (like I like to use), the dimcenter command will generate 6 seperate lines to mark the circle center
This is for the 2 LINE dimcenter construct;
modify to suit yours.
Usually a BLOCK is used instead of the LINEs,
more useful.
For LWPOLYLINES, or INSERTs, other code must be used.
(defun dxf_ (n alst) (cdr (assoc n alst)) )
(DeFun dxf_EU (gn edL / vv ) ; return Ucs coords
(if (and (setq vv (cdr (assoc gn edL)))
(member gn (list 10 11 210 ))) ; others may exist!
(trans vv (cdr (assoc -1 edl)) 1) vv ) )
(defun c:dcg (/ SS) ; stevor 13MAY13
(if (and (setq len1 (entlast) ; ref db ent
es (entsel " Sel ARC,CIRCLE"))
(setq sen (car es) ty (dxf_ 0 (entget sen)))
(or (member ty (list "ARC" "CIRCLE"))
(and (princ "\n Ty: ")(princ ty) nil)) )
(progn
(command "DIMCENTER" es )
(if (/= len1 (entlast) )
(progn (princ " grouper ")
(setq en2 (entnext len1) en3 (entnext en2)
es2 (list en2 (dxf_eu 10 (entget en2)))
es3 (list en3 (dxf_eu 10 (entget en3))) )
(command "-group" "C" "*" "" es2 es3 "" )
(princ" Ty: ")(prin1 (dxf_ 0 (entget sen))) ) ) (princ) )
( c:dcg )
(princ" done" ))
@CheleCity wrote:Anybody ever write a routine that would group center marks after using dimcenter? Thanks.
Here's my take on it:
(defun C:DCG (/ last dcgss); = DimCenter with Grouping of resulting lines
(setq
last (entlast)
dcgss (ssadd)
); setq
(if (/= (getvar 'dimcen) 0)
(progn ; then
(command "_.dimcenter")
(while (> (getvar 'cmdactive) 0) (command pause))
; allows for missed pick, wrong object type, etc.
(while (setq last (entnext last)); whether 2 or 6 Lines
(ssadd last dcgss); add them to selection
); while
(command "_.group" "" "*" "" dcgss ""); make into unnamed Group
); progn
(alert "DIMCEN System Variable must be non-zero."); else
); if
(princ)
); defun
