this is the current enviroment:
And these are the results of Getvar acadprefix. How is that possible? I rant this on six or so products from 2 suite and got the correct results except for AcadArchitecture. Why would it ignore the first three search paths?
C:\\Users\\jbouza\\AppData\\Roaming\\Autodesk\\ACA 2014\\enu\\SUPPORT;
C:\\Program Files\\Autodesk\\AutoCAD 2014\\support;
C:\\Program Files\\Autodesk\\AutoCAD 2014\\support\\en-us;
C:\\Program Files\\Autodesk\\AutoCAD 2014\\fonts;
C:\\Program Files\\Autodesk\\AutoCAD 2014\\help;
C:\\Program Files\\Autodesk\\AutoCAD 2014\\express;
C:\\Program Files\\Autodesk\\AutoCAD 2014\\support\\color;
C:\\Program Files\\Autodesk\\AutoCAD 2014\\ACA;
C:\\ProgramData\\Autodesk\\ACA 2014\\enu\\Layers\\;
C:\\Program Files\\Autodesk\\AutoCAD Raster Design 2014\\;
C:\\Program Files\\Autodesk\\ApplicationPlugins\\SBD4.bundle\\Contents\\AALSBin;
C:\\ProgramData\\Autodesk\\ApplicationPlugins\\Autodesk AppManager.bundle\\Contents\\Resources;
C:\\ProgramData\\Autodesk\\ApplicationPlugins\\Autodesk AppManager.bundle\\Contents\\Windows\\2014;
C:\\ProgramData\\Autodesk\\ApplicationPlugins\\Autodesk FeaturedApps.bundle\\Contents\\Windows\\2014;
C:\\ProgramData\\Autodesk\\ApplicationPlugins\\Autodesk ImportSkp.bundle\\Contents\\Resources;
Joe Bouza
Same results here and I even have mine set to mapped network drive names.
I take that back, mapped network drives work.
C:\Users\%USERNAME%\appdata\roaming\autodesk\c3d 2013\enu\support;C:\program files\autodesk\autocad civil 3d 2013\support;C:\program files\autodesk\autocad civil 3d 2013\support\en-us;C:\program files\autodesk\autocad civil 3d 2013\fonts;C:\program files\autodesk\autocad civil 3d 2013\help;C:\program files\autodesk\autocad civil 3d 2013\express;C:\program files\autodesk\autocad civil 3d 2013\support\color;C:\program files\autodesk\autocad civil 3d 2013\civil;C:\program files\autodesk\autocad civil 3d 2013\bin\fdo;C:\programdata\autodesk\c3d 2013\enu\data\symbols\mvblocks;K:\cad standards;K:\cad standards\shx;C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\drv;
Joe Bouza
Joe Bouza
Probably has to do with the "\\" in front was my first thought. Instead of leaving it as an open network path, we have the server mapped on everyone's computer here as "K:"
It doesn't have that issue with the 6 other products that all use UNC paths?
"\\\\cameronfs1\\autodesk\\acad support\\acad2014 support\\lisp;\\\\cameronfs1\\autodesk\\acad support\\acad2014 support\\library;C:\\Users\\jbouza\\appdata\\roaming\\autodesk\\autocad 2014\\r19.1\\enu\\support;C:\\program files\\autodesk\\autocad 2014\\support;C:\\program files\\autodesk\\autocad 2014\\support\\en-us;C:\\program files\\autodesk\\autocad 2014\\fonts;C:\\program files\\autodesk\\autocad 2014\\help;C:\\program files\\autodesk\\autocad 2014\\express;C:\\program files\\autodesk\\autocad 2014\\support\\color;C:\\program files\\autodesk\\autocad raster design 2014\\;C:\\programdata\\autodesk\\applicationplugins\\autodesk importskp.bundle\\contents\\resources;C:\\programdata\\autodesk\\applicationplugins\\autodesk featuredapps.bundle\\contents\\windows\\2014;C:\\Program Files\\Autodesk\\ApplicationPlugins\\SBD4.bundle\\Contents\\AALSBin;C:\\ProgramData\\Autodesk\\ApplicationPlugins\\Autodesk AppManager.bundle\\Contents\\Resources;C:\\ProgramData\\Autodesk\\ApplicationPlugins\\Autodesk AppManager.bundle\\Contents\\Windows\\2014;"
Joe Bouza
Interesting.
I remember seeing a post from LeeMac that had coded a method to strip "//" but not "/" from a string
where, or even...which forum it was in I cannot remember unfortunately 😞
I'll try to though..
