The *PARAM* method means different things for different objects. In the
case of a polyline, it means a 'REAL number representing the position on the
polyline counting by primary vertices.
Here's an example:
(defun c:splitpoly ( / e ent etyp osmode cmd object closed
start end dist midp z)
(while (setq e (car (entsel "\nSelect a polyline to split: ")))
(setq ent (entget e)
etyp (cdr (assoc 0 ent))
object (vlax-ename->vla-object e)
(if (wcmatch etyp "LWPOLYLINE,POLYLINE")
(progn
(setq osmode (getvar "osmode")
cmd (getvar "cmdecho")
closed (= (logand (cdr (assoc 70 ent)) 1) 1)
end (vlax-curve-getendparam object)
dist (* 0.5 (vlax-curve-getDistAtParam object end))
midp (vlax-curve-getPointAtDist object dist)
(if (= etyp "LWPOLYLINE")
(setq z (cdr (assoc 38 ent))
start (cdr (assoc 10 ent))
start (list (car start)(cadr start) z)
midp (list (car midp)(cadr midp) z)
(setq start (cdr (assoc 10 (entget (entnext e)))))
(setvar "osmode" 0)
(setvar "cmdecho" 0)
(command "_.break" e (trans midp 0 1) "@")
(if (and closed (= etyp "LWPOLYLINE"))
(command "_.break" e (trans start 0 1) "@")
(setvar "osmode" osmode)
(setvar "cmdecho" cmd)
(prompt (strcat "\nPolyline split into " (rtos dist) " long
pieces"))
(prompt (strcat " Object selected is a(n) " etyp))
(princ)
John Uhden, Cadlantic/formerly CADvantage
--> mailto:juhden@cadlantic.com
--> http://www.cadlantic.com
2 Village Road
Sea Girt, NJ 08750
Tel. 732-974-1711
FAX 732-528-1332
"jmodglin" wrote in message
news:f084f7f.2@WebX.maYIadrTaRb...
> Thanks Cliff, That was way too easy. I have never really understood the
meaning of parameter as used by AutoCAD Methods. Could somebody give me
direction on when (besides in this case) that I can used the **Param
Methods? Thanks. Joshua Modglin
