Getting length of closed polyline using VISUAL LISP EXTENSIONS
5 REPLIES 5
jmodglin
195 Views, 5 Replies
Good day all. I have some routines that I am trying to get the length of a polyline. I use the follwing: (SETQ ENT (VLAX-ENAME->VLA-OBJECT (SSNAME SS (- CNT 1)))) (SETQ ELTH (VLAX-CURVE-GETDISTATPOINT ENT (VLAX-CURVE-GETENDPOINT ENT))) . That works fine unless the polyline is closed and then I have to resort to the old "AREA" command. Is there a Method (or Methods) that can get the distance of a closed Polyline? Thanks for any help. Joshua Modglin
5 REPLIES 5
in reply to: jmodglin
Joshua,
I haven't worked with the curve functions a great deal. Have you tried
getting the end param and then using getDistAtParam?
There is an ActiveX wish list on the VBA group (the fact that is wasn't
posted here may be telling us something) where you could ask for a Length
property for polyline objects.
Cliff
"jmodglin" wrote in message
news:f084f7f.-1@WebX.maYIadrTaRb...
Joshua,
My curiousity got the best of me. Try this out. I only tested it on a
closed old-style polyline.
(defun c:len ( / e ep d)
(if (setq e (car (entsel)))
(setq
e (vlax-ename->vla-object e)
ep (vlax-curve-getEndParam e)
d (vlax-curve-getDistAtParam e ep)
Cliff
jmodglin
Thanks Cliff, That was way too easy. I have never really understood the meaning of parameter as used by AutoCAD Methods. Could somebody give me direction on when (besides in this case) that I can used the **Param Methods? Thanks. Joshua Modglin
Already asked for there. I will reinforce the issue of a closed pline. But
it isn't only Autodesk that has forgotten about closed plines, in many cases
I have seen other routines to get pline length that forgot about closed
plines too (including closed *with* bulges!).
R. Robert Bell, MCSE
http://www.acadx.com
"Cliff Middleton" wrote in message
news:4F46884D584BA37A40E31A32AD620DC0@in.WebX.maYIadrTaRb...
| Joshua,
| Cliff
The *PARAM* method means different things for different objects. In the
case of a polyline, it means a 'REAL number representing the position on the
polyline counting by primary vertices.
Here's an example:
(defun c:splitpoly ( / e ent etyp osmode cmd object closed
start end dist midp z)
(while (setq e (car (entsel "\nSelect a polyline to split: ")))
(setq ent (entget e)
etyp (cdr (assoc 0 ent))
object (vlax-ename->vla-object e)
(if (wcmatch etyp "LWPOLYLINE,POLYLINE")
(progn
(setq osmode (getvar "osmode")
cmd (getvar "cmdecho")
closed (= (logand (cdr (assoc 70 ent)) 1) 1)
end (vlax-curve-getendparam object)
dist (* 0.5 (vlax-curve-getDistAtParam object end))
midp (vlax-curve-getPointAtDist object dist)
(if (= etyp "LWPOLYLINE")
(setq z (cdr (assoc 38 ent))
start (cdr (assoc 10 ent))
start (list (car start)(cadr start) z)
midp (list (car midp)(cadr midp) z)
(setq start (cdr (assoc 10 (entget (entnext e)))))
(setvar "osmode" 0)
(setvar "cmdecho" 0)
(command "_.break" e (trans midp 0 1) "@")
(if (and closed (= etyp "LWPOLYLINE"))
(command "_.break" e (trans start 0 1) "@")
(setvar "osmode" osmode)
(setvar "cmdecho" cmd)
(prompt (strcat "\nPolyline split into " (rtos dist) " long
pieces"))
(prompt (strcat " Object selected is a(n) " etyp))
(princ)
John Uhden, Cadlantic/formerly CADvantage
--> mailto:juhden@cadlantic.com
--> http://www.cadlantic.com
2 Village Road
Sea Girt, NJ 08750
Tel. 732-974-1711
FAX 732-528-1332
news:f084f7f.2@WebX.maYIadrTaRb...
”Boost
