Visual LISP, AutoLISP and General Customization
Getting a block flat, using error handler problem
3 REPLIES 3
ChuckEdwards
255 Views, 3 Replies
I've written the little routine below. Something is going wrong with how the variable ent is passed but I can't work out what, any suggestions?
The core code works fine, if I comment out the catch-all-apply code, and de-comment the rest of the second module, it works fine. not what i want though, I'd like to avoid problems like trying to change the normal of an object on a locked layer.
(defun flattenblock (ent / newNormal)
  (setq enx (vlax-ename->vla-object ent))
  (setq newNormal (vlax-3d-point 0 0 1))
  (vla-put-Normal enx newNormal)
  (vla-Update enx)
  (setq newNormal (vlax-variant-value newNormal))
;;selection routine
(defun c:flatblock (/ ent ss enx newNormal)
  (vl-load-com)
  (while (null ss)
    (prompt "\nSelect Blocks or Xrefs")
    (setq ss (ssget '((0 . "INSERT"))))
  (while (> (sslength ss) 0)
    (setq ent (ssname ss 0))
      (setq
        catchit (vl-catch-all-apply 'flattenblock ent)
   ; (setq enx (vlax-ename->vla-object ent))
  ;  (setq newNormal (vlax-3d-point 0 0 1))
  ;  (vla-put-Normal enx newNormal)
  ;  (vla-Update enx)
   ; (setq newNormal (vlax-variant-value newNormal))
    (ssdel ent ss)
  )        ;end while
  (princ)
3 REPLIES 3
Lee_Mac
in reply to: ChuckEdwards
The issue is because the vl-catch-all-apply function requires a list of arguments to which the supplied function is to be applied - similar in operation to the apply function, but will catch any exceptions.
However, I would suggest the following:
(defun c:flatblock ( / e i n s )
    (if (setq s (ssget "_:L" '((0 . "INSERT"))))
        (repeat (setq i (sslength s))
            (setq e (entget (ssname s (setq i (1- i))))
                  n (assoc 210 e)
            (entmod
                (subst
                    (cons  10 (trans (cdr (assoc 10 e)) (cdr n) 0))
                    (assoc 10 e)
                    (subst '(210 0.0 0.0 1.0) n e)
    (princ)
ChuckEdwards
in reply to: Lee_Mac
Thanks.
I think I'll stick with the VLAX, I get lost in the parenthesiseseses....
Charles.
Lee_Mac
Vanilla AutoLISP is faster and has fewer bugs, but your choice.
For the Visual LISP (ActiveX) route:
(defun c:flatblock ( / i p s )
            (setq o (vlax-ename->vla-object (ssname s (setq i (1- i))))
                  p (vlax-get o 'insertionpoint)
            (vlax-put o 'normal '(0.0 0.0 1.0))
            (vlax-put o 'insertionpoint p)
    (princ)
(vl-load-com) (princ)
”Boost
