Getting Lisp to total values in attributes
14 REPLIES 14
Message 1 of 15
rodb
763 Views, 14 Replies
I've never attempted to get Lisp to total up values contained in a block attribute. So a collection of blocks with  variable quantity of attributes. To search through them and total up the intergers in each "watts" attribute tag of each block that has the same interger value in its "location" attribute tag.
so
block number 1 has 2 in Location tag and 50 in its watts tag
block number 2 has 2 in Location tag and 40 in its watts tag
block number 3 has 4 in Location tag and 25 in its watts tag
block number 4 has 3 in Location tag and 30 in its watts tag
block number 5 has 4 in Location tag and 66 in its watts tag
etc
this produces a txt file with
Location 2 = 90 watts
Location 3 = 30 watts
Location 4 = 91 watts
etc
I think this is really tricky with Lisp because you can't add variables together?
or could you loop through the selection set of blocks looking for location 1 then adding the watt values together, then repeat the loop through the selection set of all blocks and look for location 2 etc But how would you know when to stop because you may have anything from 1 location to 50 locations. I'm going to try and get some sleep now!!!!
14 REPLIES 14
Message 2 of 15
hmsilva
in reply to: rodb
Hi rodb.
A quick and dirty one, and only as a "demo"...
Untested
(defun c:demo (/ a attlst b ent fn hnd i lst obj of s1)
  (vl-load-com)
  (if (and (setq fn (getfiled "" (getvar 'DWGPREFIX) "txt" 1))
	   (setq s1 (ssget '((0 . "INSERT") (66 . 1))))
    (progn
      (repeat (setq i (sslength s1))
	(setq hnd    (ssname s1 (setq i (1- i)))
	      ent    (entget hnd)
	      attlst nil
	      obj    (vlax-ename->vla-object hnd)
	      attlst (vlax-invoke obj 'GetAttributes)
	);; setq
	(foreach att attlst
	  (cond	((= (vla-get-TagString att) "Location")
		 (setq a (vla-get-TextString att))
		((= (vla-get-TagString att) "watts")
		 (setq b (atoi (vla-get-TextString att)))
	  );; cond
	);; foreach
	(if (and a b)
	  (progn
	    (if	(assoc a lst)
	      (setq lst	(subst (cons a (+ b (cdr (assoc a lst)))) (assoc a lst) lst))
	      (setq lst (cons (cons a b) lst))
	    );; if
	    (setq a nil b nil)
	  );; progn
	);; if
      );; repeat
      (if lst
	(progn
	  (setq lst (vl-sort lst (function (lambda (a b) (< (car a) (car b))))))
	  (setq of (open fn "w"))
	  (foreach l lst
	    (write-line (strcat "Location " (car l) " = " (itoa (cdr l)) " watts") of)
	  );; foreach
	  (close of)
	);; progn
      );; if
    );; progn
  );; if
  (princ)
);; demo
Hope that helps
Henrique
Message 3 of 15
3wood
in reply to: rodb
Without any lisp, just use ATTOUT in Express Tools to export the attribute informaiton as a txt file, then open it in Excel.
You can sort the data in Excel by "Location tag", as shown below:
Then just select all cells under the same "Location" and the sum is at bottom-right of Excel window.
Message 4 of 15
rodb
in reply to: hmsilva
Really strange, it seems to work fine no errors reported but the file does not appear to get written. It asks for a location to save the file but when I look there the file does not exist???? Would be amazing if you can get it to write the file?
Message 5 of 15
pbejse
in reply to: rodb
Quick glance, change these items on the code
"Location" to "LOCATION"
"watts" to "WATTS"
HTH
Message 6 of 15
rodb
in reply to: 3wood
Thank you for your input. I have suggested that for now and I do if fact do that for the circuits in a drawing having written a VBA script for Excel which automatically adds the circuits up and saves a prn file to import onto a grid in Autocad and I suppose I could make another VBA to do that with the watts but would love to find out how to do it in lsp!
Message 7 of 15
hmsilva
in reply to: rodb
Hi rodb,
post a sample block with the attributes...
Henrique
Message 8 of 15
rodb
in reply to: pbejse
That works but this is what I get
Location  = 197 watts
problem is I need a total for each location as in
Location 2 = 10 watts
Location 3 = 23 watts
Location 4 = 50 watts
etc.
so how do you carry a value in a variable as in loc2watt then add to it when you find another Location 2 attribute watt value?
Am really trying to avoid going into Excel but will write a VBA if I have to.
Message 9 of 15
rodb
in reply to: rodb
Here is the test dwg
Message 10 of 15
hmsilva
in reply to: rodb
rodb,
if you don't have the Location filled with a value the code would error...
Try this version
  (vl-load-com)
    (progn
	      ent    (entget hnd)
	      attlst nil
	);; setq
	(foreach att attlst
	  (cond	((and (= (strcase (vla-get-TagString att)) "LOCATION")
		      (/= (vla-get-TextString att) ""))
		((and (= (strcase (vla-get-TagString att)) "WATTS")
	  );; cond
	);; foreach
	(if (and a b)
	  (progn
	    (if	(assoc a lst)
	    );; if
	    (setq a nil b nil)
	  );; progn
	);; if
      );; repeat
      (if lst
	(progn
	  (foreach l lst
	  );; foreach
	  (close of)
	);; progn
      );; if
    );; progn
  );; if
  (princ)
);; demo
To have a valid txt you'll have to put some values at Location tag...
HTH
Henrique
Message 11 of 15
pbejse
Suggestions
Regarding the sequence, only prompt for file to save if and only if there are datas found
Launch notepad to quickly see the result --> (startapp "notepad" fn)
Message 12 of 15
hmsilva
in reply to: pbejse
@pbejse wrote:
Suggestions
Good suggestions, pBe!
Cheers
Henrique
Message 13 of 15
rodb
Amazing it works that is SO clever! and so much easier than going in and out of Excel. Its awesome, thank you!
I did get an error message see below when changing some of the wattage values to test it but that went away when I re-ran it.
Command: DEMO
Select objects: all
24 found
Select objects:
; error: Exception occurred: 0xC0000005 (Access Violation)
; warning: unwind skipped on exception
Command:
Message 14 of 15
rodb
in reply to: pbejse
Thats a great idea too! it always amazes me how its possible to make AutoCAD do just about anything if you have the brains for it!
Message 15 of 15
hmsilva
in reply to: rodb
Command: DEMO
Select objects: all
24 found
Select objects:
Command:
You're welcome, rodb!
Regarding the error, I don't see anything that might cause this error in code, try reopen AutoCAD...
Henrique
”Boost
