Visual LISP, AutoLISP and General Customization
Get folder name up one level.
3 REPLIES 3
XIJIANGWOO
851 Views, 3 Replies
Hi guys,
I am currently using this code to get the folder name containing the current drawing.
FolderName = Dir(ThisDrawing.path, vbDirectory)
 What would I use if I wanted to get the foldername one level up (third)?
ex. C:\FIRST\SECOND\THIRD\FOURTH
Any help is greatly appreciated.
Shawn
3 REPLIES 3
Kent1Cooper
in reply to: XIJIANGWOO
I don't know about that kind of code, but in AutoLISP terms:
If
(setq filepath (getvar 'dwgprefix))
returns
"K:\\FIRST\\SECOND\\THIRD\\FOURTH\\"
then you can trim off after the next-to-last \ character:
(substr
  filepath
  1
  (1+
    (vl-string-position
      (ascii "\\")
      (vl-string-right-trim "\\" filepath)
      nil T
    ); vl-string-position
  ); 1+
); substr
returns
"K:\\FIRST\\SECOND\\THIRD\\"
Kent Cooper, AIA
pbejse
One folder down
(findfile
(strcat (getvar 'dwgprefix)
HTH
BigDumbWeirdo
@XIJIANGWOO wrote:
Hi guys,
Shawn
FolderArray = Split(FolderName, "\")
DesiredFolderName = FolderArray(FolderArray.length() - 2)
 I haven't tested it, but it should work as is.
”Boost
