Visual LISP, AutoLISP and General Customization
Get a 3rd party object with ObjectDBX or native lisp.
2 REPLIES 2
mdhutchinson
302 Views, 2 Replies
Ultimately I want to count a 3rd party objects, when the drawing is closed....  But a side note first...
I would have thought that this would have worked when the drawing is open... I double checked the spelling and it is correct.
But it does not work. Shouldn't this be possible?
(setq ss (ssget "X" (list (cons 0 "CompXHangerPnt"))))
(For sake of discussion I've have fictitious name in the example here).
... could it work somehow with activeX vla- functions?
2 REPLIES 2
owenwengerd
in reply to: mdhutchinson
What you have should work fine as long as the entities are in model or paper space, you just need to use the correct DXF name.
Owen Wengerd
ManuSoft
As far as I remember if  parameter DXF_NAME in ACRX_DXF_DEFINE_MEMBERS macro of custom entity is not fully uppercase  -  (ssget "_X" <dxf-name>) is not working properly and return nil.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
”Boost
