Ultimately I want to count a 3rd party objects, when the drawing is closed.... But a side note first...
I would have thought that this would have worked when the drawing is open... I double checked the spelling and it is correct.
But it does not work. Shouldn't this be possible?
(setq ss (ssget "X" (list (cons 0 "CompXHangerPnt"))))
(For sake of discussion I've have fictitious name in the example here).
... could it work somehow with activeX vla- functions?
What you have should work fine as long as the entities are in model or paper space, you just need to use the correct DXF name.
As far as I remember if parameter DXF_NAME in ACRX_DXF_DEFINE_MEMBERS macro of custom entity is not fully uppercase - (ssget "_X" <dxf-name>) is not working properly and return nil.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
