I rename visibility states all the time to something other
than the default. Your memory must be much better
than mine if you can always remember the parameter
names for every dynamic block you've ever created.
I was looking for more of a generic solution that required
minimum input from the user. Looks like the parameter
name is a must have argument in this case.
Autodesk Discussion Group Facilitator
"Allen Johnson"
wrote in message
news:5802085@discussion.autodesk.com...
Why wouldn't you know the name of the visibility state?
Visibility States (as well as all other dynamic block properties) are pretty
custom to the block it is referenced in.
If you created the block or are using it, surely you can determine the name.
If you didn't know the name (and its purpose) why are going to modify it,
since you probably don't know what it is going to do.
