I'm creating a routine and I'm missing some basic functions from the data
sectors of my brain to complete it :)
What I need to do is have two lines: nb & nb2, trim from each other (or
fillet) and also trim from the outside of a circle: c (located at the
intersection of the two lines), with a point: p, that defines which side is
"positive."
Here is a clip from the routine:
(setq p (getpoint "Pick side to offset: "))
;trim lines from each other like a fillet
(command "TRIM" nb "" nb2 "")
(command "TRIM" nb2 "" nb "")
;trim lines outside of circle
(command "TRIM" c "" nb nb2 "")
But this only works when the resulting lines are shaped like a V and the
point is up. I hope this makes sense, I'm a bit hungry and that may affect
my coherence :)
Thanks!
