• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Visual LISP, AutoLISP and General Customization
    Member
    Accepted Solution
    Finding multiple text strings and change formats
    239 Views, 8 Replies
    04-23-2012 06:43 AM
    I am trying to select multiple instances of text (dtext) with different strings but want to change all of the fomats to the same settngs.  I have searched high and low on the web to no avail.  I am using AutoCAD 2012.
    For example:  I want the routine to find all instances of "AA", "AB", "AC", "AD", "BA", "BB", "BC", "BD", etc... all the way up to "ZD".
    Next I want all of those text entities to change to the following text formats:
    • Text Style = STANDARD_96
    • Layer = F-ANNO-CKT
    • Text Justification = MIDDLE CENTER
    • Text Width = .8
    Getting this to work with just finding one string at a time with the ssget function seems simple enough, but it's getting it to work with multiple strings that I can't get past.  Any help or direction to a similar routine I can modify would be greatly apprechiated.
    Rob
    Please use plain text.
    Active Contributor
    MetroVancouverDrafting
    Re: Finding multiple text strings and change formats
    04-23-2012 09:26 AM in reply to: rseyda
    paste in the command line (ssget "x" '((0 . "text")(1 . "@@")))
    then use select Previous
    @@ means any two alphabetic characters
    *Expert Elite*
    Kent1Cooper
    04-23-2012 09:46 AM in reply to: MetroVancouverDrafting
    Caddhelp wrote:
    ....(ssget "x" '((0 . "text")(1 . "@@")))
    That will, of course, find any two-alphabetic-character strings, which may include some that don't qualify [with lower-case characters, and/or second characters past D].  One way to check individual text strings in the resulting selection set, and process them only if they're the right kind of letter combination, is to put a Text entity's text content into a variable that I'll call 'txt', and then:
    (if
      (and
        (< 64 (ascii (substr txt 1 1)) 91); first character upper-case A to Z
        (< 64 (ascii (substr txt 2)) 69); second character upper-case A to D
      ); and
      (.... change its properties, by whatever means ....)
    ); if
    Kent Cooper
    Active Contributor
    04-23-2012 10:08 AM in reply to: Kent1Cooper
    Thanks to point it out, I did not read the post carefuly
    This ssget will select any text that has two characters: first between A and Z and second between A and D
    (ssget "x" '((0 . "text")(1 . "[A-Z][A-D]")))
    Member
    04-23-2012 11:35 AM in reply to: MetroVancouverDrafting
    Thanks for the help.  It's been several years since I played with Lisp, so unfortunately I am very rusty.  I copied and pasted the (ssget "x" '((0 . "text")(1 . "[A-Z][A-D]"))) into the command line, and the result is a selection set number, but it doesn't actually select anything.  However if I type in SELECT, then P, I am then able to select the objects and then invoke the DDCHPROP command (CHPROP command limits the amount of properties you can change via command line).
    So I started to wonder if maybe I can just run this in a script file instead of spending hours trying to recall autolisp due to it's simplicity.  But when I type into the script file exactly what I typed on the command line, I get a command not found error for DDCHPROP.  Here is my script:
    select
    p
    ddchprop
    I know I must be missing something very simple here, and I plan to accept my embarrasment like a man.  If I have to continue with writing a lisp routine I will, but I was looking for a quicker fix naturally.
    Active Contributor
    04-23-2012 12:52 PM in reply to: rseyda
     command DDCHPROP
    in the top left corner there is a button, QuickSelect, press it.
    in the next dialog
    Apply to       : Entire Drawing
    Object Type :Text
    Properties    : Contents
    Operator      : * Wildcard Match
    Value          :  [A-Z][A-D]
    Member
    04-23-2012 01:24 PM in reply to: MetroVancouverDrafting
    Wow...I knew there was an easier way...but geez...it was THAT easy?  I feel more ashamed than embarrased!
    Thanks for the help!
    Active Contributor
    04-23-2012 02:35 PM in reply to: rseyda
    mark it as solved
    *Expert Elite*
    04-23-2012 10:38 PM in reply to: rseyda
    • Text Width = .8
    Rob
    I suppose the text width would depend on the  STANDARD_96 text style in  which you dont need to modify that entry.. otherwise you need to override DXF 41 or ScaleFactor (VL) for  every selected text entity.
