Show only
Search instead for
> You're most welcome, lottsa good stuff at the mvps site 🙂
Yeah, I feel right at home. Writing Vlisp programs using VB code samples!
> (reasons-for-failure (dos_find "winword.exe"))
> ( "1: Ummm, is the app actually on this machine?"
> "2: Is the current drive not the same as app's drive?"
> "3: Is the current version of DosLib wonkey?"
> "4: Errr ..."
2 is the reason. Who fires autocad in the winword executable path? I think
Frank and Luis' approaches are next best to the winapi route. Wish I had
time to work on it. It would be a nice diversion.
Well, here is something that I was able to recover (do not know if is a
latest version, since I just happen to lost about two years of
code...#%$)... Just remove the obvious lines... 🙂
(defun editor (file / arch key version apps dir f word wordpad)
(appload "SHORTFN14.ARX")
(vlisp-import-exsubrs '("SHORTFN14.ARX" "shortfn"))
(setq arch (shortfn file)
key "HKEY_LOCAL_MACHINE\\Software\\Microsoft\\office"
version (vl-registry-descendents key))
(if version
(progn
(vl-some
'(lambda (vers)
(setq apps (vl-registry-descendents
(strcat key "\\" vers)))
(if (vl-some '(lambda (app) (= app "Word")) apps)
(progn
(setq dir (vl-registry-read
(strcat key
vers
"\\Word\\InstallRoot")
"Path"))
(if dir
(if
(setq f
(findfile
(strcat
(substr dir 2 (- (strlen dir) 2))
"\\winword.exe")))
(progn
arch))
(setq wordpad T))))))
(if (and (not word) (not wordpad))
(command "._SHELL" (strcat "EDIT " arch))))))
It's a shame we have to do real work whilst so many pet projects despair of
their unrequited bit bashing. It's just not right 😞
"Cliff Middleton" wrote in message
news:812414DE15BE06500D10F7994019C735@in.WebX.maYIadrTaRb...
> > "4: Errr ..."
think
