Active Contributor
ditran
Message 1 of 6 (520 Views)
Find current lisp file path
520 Views, 5 Replies
09-05-2013 12:45 AM
Hi All,
Is there any way to find the path of current lisp file. For example,If we located test.lsp file on C driver, the function will return "C:\test.lsp".etc...
Thanks for any help.
Lee_Mac
Message 2 of 6 (508 Views)
Re: Find current lisp file path
09-05-2013 02:20 AM in reply to: ditran
What do you mean by 'current lisp file'?
Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
Expert Elite
With Mathematics there is the possibility of perfect rigour, so why settle for less?
Distinguished Contributor
bhull1985
Message 3 of 6 (496 Views)
09-05-2013 04:09 AM in reply to: ditran
(findfile "yourfile.lsp") in autocad will return the location of "yourfile" within the autocad search paths, if it exists...
hopefully that helps
Please use code tags and credit where credit is due. Accept as solution, if solved. Let's keep it trim people!
Active Contributor
ditran
Message 4 of 6 (475 Views)
09-05-2013 06:19 PM in reply to: bhull1985
Thanks for reply. But I want to find the saved path of lisp file being edited. I want to load other file in same folder which located anywhere.Maybe it's not loacted in Autocad search path.
Valued Mentor
bgingerich
Message 5 of 6 (436 Views)
09-06-2013 06:26 AM in reply to: ditran
There may be a way to retrieve the "last opened file" location from a registery entry somewhere?  I only have LT at the moment, so I can't help you with the actual entry.
This is the folder for recent files in 2010 LT.  May or may not help you...
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD LT\R15\ACADLT-8001:409\Recent File List
HTH
Brandon Gingerich
Lee_Mac
Message 6 of 6 (429 Views)
09-06-2013 06:35 AM in reply to: ditran
If you are referring to a LISP file that is being edited within the Visual LISP IDE, you could read the *edit-file-history* section of the VLIDE.DSK file.
Expert Elite
You are not logged in.
Ask the Community
