• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Valued Contributor
    Find and replace multileader text with LISP
    753 Views, 14 Replies
    01-25-2012 09:15 AM
    I'm looking for a lisp routine that can find and replace multileader text.
    I want to replace "T." with "T+" and "B." with "B+".
    All the multileaders are on layers with a suffix of "-elev".
    Any help will be greatly appreciated.
    Thanks in advance,
    Larry
    Please use plain text.
    Re: Find and replace multileader text with LISP
    01-26-2012 03:07 AM in reply to: bdsmls
    Thanks in advance,
    Larry
    command:  _find
    settings....
    Text types
    Dimension/Leader text
    Why the need for lisp codes?
    Anyway, since i'm replying.
    (defun c:REpME  (/ sel e)
          (setq sel (ssget "_X" '((0 . "MULTILEADER")(8 . "*-elev"))))
          (repeat (sslength sel)
                (setq e (vlax-ename->vla-object (ssname sel 0)))
                (vla-put-textstring
                      e
                      (vl-string-translate
                            "B.T."
                            "B+T+"
                            (vla-get-textstring e)))
                (ssdel (ssname sel 0) sel)
    HTH
    01-26-2012 05:14 AM in reply to: pbejse
    Scratch the previous post
    This is more specific:
          (if (setq sel (ssget '((0 . "MULTILEADER")(8 . "*-elev"))))
    	                   str (vla-get-textstring e))
    	            (if (setq f
    		            (cond
    		            	((wcmatch str "*B.*") (list "B." "B+"))
    			        ((wcmatch str "*T.*") (list "T." "T+"))))
    			(vla-put-textstring e
    	                (vl-string-subst (cadr f)(car f) str) )
              (princ)
    Valued Contributor
    01-26-2012 09:34 AM in reply to: bdsmls
    That's what i was looking for. Thanks for your help.
    Larry
    alanjt_
    01-26-2012 01:19 PM in reply to: pbejse
    @pbejse: FYI, wcmatch IS case sensitive.
    01-26-2012 09:27 PM in reply to: alanjt_
    You are absolutely right.. my mistake :smileywink:
    Thanks Alanjt.....
    Member
    bbarkman.jedson
    10-08-2012 12:58 PM in reply to: bdsmls
    Would this work if a block with an attribute is embedded in the multileader?
    10-08-2012 08:14 PM in reply to: bbarkman.jedson
    Yes i think its possible, what do you have in mind?
    Member
    bbarkman.jedson
    10-09-2012 06:12 AM in reply to: pbejse
    Our revision tag is a block embedded in a multileader with the one attribute (REVNUM). I am prompting the user for the current revision letter/number (so the routine knows which values to look for) and the desired revision. I'd like to check the current value from the user against what's in the multileader. If there's a match, change it. If not, do nothing. In the same routine I'm also looking at regular blocks via the attribute name. That way if a block or multileader with that block is inserted they all get checked. When the attribute tag name is found the routine proceeds accordingly. This works fine with regular blocks. The only thing missing is the "if" action for multileaders. They get changed no matter what, which means a revision tag could be altered when it shouldn't. The current code is attached. Much of it was provided by Lee McDonnell.
    Member
    bbarkman.jedson
    10-09-2012 06:14 AM in reply to: bdsmls
    Here's the code.
