Filtering a list
15 REPLIES 15
Message 1 of 16
609 Views, 15 Replies
Filtering a list
I want to filter a list on the value of each second item in the list.
Something like this;
(filterlist '(("1" "X") ("1" "D") ("2" "D")) 2 "D")
To result in this;
(("1" "D") ("2" "D"))
Does anyone know is there already is something standard for this?
If not, I'll write something myself, but I'm always open to solutions of
others : )
Cheers,
M
15 REPLIES 15
Message 2 of 16
Now I do this;
(defun filterlist (flt n lst / lstn)
(foreach itm lst (if (= (nth (1- n) itm) flt) (setq lstn (append lstn
(list itm))))) lstn
"M. Janmaat" schreef in bericht
news:6267278@discussion.autodesk.com...
To result in this;
others : )
Cheers,
M
Message 3 of 16
M. Janmaat wrote:
> Hi,
> To result in this;
> others : )
> Cheers,
> M
VL-REMOVE-IF
VL-REMOVE-IF-NOT
Message 4 of 16
Thanks!
"Martti Halminen" schreef in bericht
news:6267314@discussion.autodesk.com...
M. Janmaat wrote:
> Hi,
> To result in this;
> others : )
> Cheers,
> M
VL-REMOVE-IF
VL-REMOVE-IF-NOT
Message 5 of 16
There's nothing standard other than the AutoLISP functions reference as
presented in the Help. Whatever is not there, has to be built and kept in
your personal library : )
As for your problem, maybe it's a good idea that you elaborate a little more
about what you want to do, because your example is a little bit ambiguous,
because I could have the same result if I remove every item list in your
general list which doesn't have "D" as second element and then sort the
resulting list, but then I don't understand what is the 'n' argument for:
(defun filter (lst flt)
(vl-sort
(vl-remove-if
'(lambda (x)(/= (cadr x) flt))
lst
'(lambda(x y)
(< (car x)(car y))
and then
Commande: (filter '(("1" "X") ("1" "D") ("2" "D")) "D")
will return
Humans are born with a wide horizon.
As time goes by, the horizon narrows and
narrows, until it becomes a point of view.
"M. Janmaat" a écrit dans le message de news:
6267279@discussion.autodesk.com...
Now I do this;
(list itm))))) lstn
To result in this;
others : )
Cheers,
M
Message 6 of 16
Kent1Cooper
The 'n' argument is for the possibility that they might want to filter for what is in some position in the sub-lists *other than the second item*, usable with a list of lists that presumably could sometimes be longer than two items. Their example used n=2 for the second item, but that wouldn't always be what they need. That's why they have
(nth (1- n) itm)
instead of
(cadr itm)
inside their original code.
The (vl-remove-if-not) function seems a more accurate "description" of what they want to do. Adjusting their optional item position into your sorted approach, but with the remove-if-not variety:
{code}
(defun FLOLI (lst n flt); for Filter List Of Lists by Item
(vl-sort
(vl-remove-if-not
'(lambda (x) (= (nth (1- n) x) flt))
lst
'(lambda (x y)
(< (car x) (car y))
{code}
But their original code leaves the list items that pass the test in their order in the original list, without sorting. If sorting is not required, it can be a lot shorter:
{code}
(vl-remove-if-not
lst
{code}
Kent Cooper
Some Buddy wrote...
....I could have the same result if I remove every item list in your general list which doesn't have "D" as second element and then sort the resulting list, but then I don't understand what is the 'n' argument for....
Kent Cooper, AIA
Message 7 of 16
I don't know, I think that a short explanation of his function would be
helpful, a little bit like how the AutoLISP native functions are presented,
function name, what it does, the arguments and what it returns. If the OP
will find his answer in your derivatives, it's even better.
6267603@discussion.autodesk.com...
(nth (1- n) itm)
instead of
(cadr itm)
{code}
(vl-sort
(vl-remove-if-not
lst
'(lambda (x y)
(< (car x) (car y))
{code}
{code}
(vl-remove-if-not
lst
{code}
Kent Cooper
Some Buddy wrote...
Message 8 of 16
stevor
Seems to work with the input list trewritten to lake lists:
(setq sl ( list (list "1" "X") (list"1" "D") (list "2" "D") ) ) ; input list
(setq rl ( FLOLI 2 sl "D" ) ) ; result list
S
Message 9 of 16
Kent1Cooper
It works either way, or by any valid way of making the List, except that the arguments need to be in a different order [list before position number]....
Command: ( FLOLI 2 sl "D" )
; error: bad argument type: listp 2
Command: ( FLOLI sl 2 "D" )
It even works if not all the sub-lists have "enough" items in them:
Command: (setq sl '((3 4 5) ("yes" 3 8 pi) (89.2 4 "whatever") (T "this" "that" 4)))
Command: (floli sl 4 4)
((T "this" "that" 4))
But if it matters, I found, in experimenting with the same list, that if pi is the element in a list that you're filtering for, you have to "do it right" with a preceding apostrophe to get what you want:
Command: (floli sl 4 pi)
nil
But:
Command: (floli sl 4 'pi)
(("yes" 3 8 PI))
That's not required with the symbols T or nil as elements in the sub-lists. I'm not sure whether there might be other things that would require some kind of special handling, as pi does.
Kent Cooper
stevor wrote...
Kent Cooper, AIA
Message 10 of 16
> nil
> But:
> (("yes" 3 8 PI))
That is just the normal Lisp evaluation rules at work: you'd need to
quote any symbol except T or nil, which are self-evaluating, like
numbers and strings.
Message 11 of 16
Hi Some,
Thanks for posting.
Now I came across the following simular "problem";
For example:
I have a list like this;
(("E_AKS" "" "" "") ("E_ARD" "DD" "0000" "") ("E_ARD" "" "" "") ("E_ARM"
"B13" "0000" ""))
I want to filter all lists with "E_ARD" as the first item. and return the
(cdr of that list
Resulting in this;
(("DD" "0000" "") ("" "" ""))
I thought I could use your solution for this. But I haven't figured uit
(yet) how...
Hope you can help.
Kind regards,
M
"Some Buddy" schreef in bericht
news:6267547@discussion.autodesk.com...
(vl-sort
(vl-remove-if
lst
'(lambda(x y)
(< (car x)(car y))
and then
will return
Now I do this;
(list itm))))) lstn
To result in this;
others : )
Cheers,
M
Message 12 of 16
This seems to work for me;
(foreach blk cgl (if (= (car blk) (substr (car itm) 1 5)) (setq xxx (append
xxx (list (cdr blk))))))
But I would like to know if you have a solition also...
news:6270550@discussion.autodesk.com...
Hi Some,
Thanks for posting.
For example:
"B13" "0000" ""))
(cdr of that list
Resulting in this;
(yet) how...
Hope you can help.
Kind regards,
M
(vl-sort
(vl-remove-if
lst
'(lambda(x y)
(< (car x)(car y))
and then
will return
Now I do this;
(list itm))))) lstn
To result in this;
others : )
Cheers,
M
Message 13 of 16
Hi Marcel,
You can try the next one and see if it suits you in all circumstances. If
you don't need it soerted it can be even shorter.
(vl-sort
(mapcar
'cdr
(vl-remove-if-not
'(lambda (x)(= (car x) flt))
lst
'(lambda(x y)
(> (car x)(car y))
Hi Some,
Thanks for posting.
For example:
"B13" "0000" ""))
(cdr of that list
Resulting in this;
(yet) how...
Hope you can help.
Kind regards,
M
(vl-sort
(vl-remove-if
lst
'(lambda(x y)
(< (car x)(car y))
and then
will return
Now I do this;
(list itm))))) lstn
To result in this;
others : )
Cheers,
M
Message 14 of 16
And you call it like this:
(filter '(("E_AKS" "" "" "")("E_ARD" "DD" "0000" "")("E_ARD" "" ""
"")("E_ARM" "B13" "0000" "")) "E_ARD")
"Some Buddy" a écrit dans le message de news:
6270572@discussion.autodesk.com...
Hi Marcel,
(vl-sort
(mapcar
'cdr
(vl-remove-if-not
lst
'(lambda(x y)
(> (car x)(car y))
Hi Some,
Thanks for posting.
For example:
"B13" "0000" ""))
(cdr of that list
Resulting in this;
(yet) how...
Hope you can help.
Kind regards,
M
(vl-sort
(vl-remove-if
lst
'(lambda(x y)
(< (car x)(car y))
and then
will return
Now I do this;
(list itm))))) lstn
To result in this;
others : )
Cheers,
M
Message 15 of 16
Thanks very much!
news:6270575@discussion.autodesk.com...
Hi Marcel,
(vl-sort
(mapcar
'cdr
(vl-remove-if-not
lst
'(lambda(x y)
(> (car x)(car y))
Hi Some,
Thanks for posting.
For example:
"B13" "0000" ""))
(cdr of that list
Resulting in this;
(yet) how...
Hope you can help.
Kind regards,
M
(vl-sort
(vl-remove-if
lst
'(lambda(x y)
(< (car x)(car y))
and then
will return
Now I do this;
(list itm))))) lstn
To result in this;
others : )
Cheers,
M
Message 16 of 16
You're welcome : )
6270596@discussion.autodesk.com...
Thanks very much!
Hi Marcel,
(vl-sort
(mapcar
'cdr
(vl-remove-if-not
lst
'(lambda(x y)
(> (car x)(car y))
Hi Some,
Thanks for posting.
For example:
"B13" "0000" ""))
(cdr of that list
Resulting in this;
(yet) how...
Hope you can help.
Kind regards,
M
(vl-sort
(vl-remove-if
lst
'(lambda(x y)
(< (car x)(car y))
and then
will return
Now I do this;
(list itm))))) lstn
To result in this;
others : )
Cheers,
M
”Boost
