How do you make field text more visible? Some text styles dont show up very well when using fields. I know you can turn fields on & off but is there a way to make the shaing lighter so the text shows up better. My font is Archquik & i'm using Autocad 2014.
Solved by rkmcswain. Go to Solution.
as far as I know, you can't control the degree of shading.
you can only control the visibility of the shading with FIELDDISPLAY.
ok, thanks. Thats too bad if true. I would like to leave the shading on to let people know that its a field but, certain fonts dont show up well
