FIND DYNAMIC BLOCK NAME THAT was STRETCHED , ROTATED
3 REPLIES 3
amyyoyo1
453 Views, 3 Replies
I am currently working with a routine that will pick up all the blocks inside of a drawing and compare it with a list of block names that I had,and use it to make a legend.
when I was testing the routine I realize that if the block had being strectched, rotated or changed from symbol with text to just symbol, the routine won't pick up the block name ,becasue autocad will assign a new name to it in the entity list (some thing like "2 . U324")which something I didn't know before.
I still really new to autolisp, and I sure someone here will know this long ago. It's there an otherway for me to pick the orginal block name not the autocad assign name?
thank you.
3 REPLIES 3
hmsilva
in reply to: amyyoyo1
Dynamic blocks,
after modify some dynamic property, becomes a anonymous block, to retrieve the block name, as a vlaobject, use the effectivename propertie
i.e.
(setq obj (vlax-ename->vla-object (car (entsel "\nSelect a DynBlock : "))))
(setq name (vlax-get-property
      obj
      (if (vlax-property-available-p obj 'effectivename)
        'effectivename
        'name
Henrique
amyyoyo1
in reply to: hmsilva
Thank you so much it work perfectly.Smiley Happy
hmsilva
You're welcome!
Glad I could help
Henrique
”Boost
