Early this year Lee_Mac presented at Exporting list of objects message the following code:
;; ExportPline - Lee Mac - www.lee-mac.com (defun c:ExportPline ( / f i o s ) (if (and (setq s (ssget '((0 . "LWPOLYLINE")))) (setq f (getfiled "Create Output File" "" "txt" 1)) (setq f (open f "w")) ) (progn (repeat (setq i (sslength s)) (setq o (vlax-ename->vla-object (ssname s (setq i (1- i))))) (write-line (apply 'strcat (vl-list* (itoa (vla-get-objectid o)) "\t" (rtos (vla-get-constantwidth o)) "\t" ( (lambda ( a ) (a (vlax-get o 'coordinates))) (lambda ( b ) (if b (cons (strcat (rtos (car b)) "," (rtos (cadr b)) "\t") (a (cddr b)) ) ) ) ) ) ) f ) ) (close f) ) ) (princ) ) (vl-load-com) (princ)
This function exports the following items from a selection of plines:
- ObjectID;
- Start Point;
- End Point;
- Vertex Points;
- and Width.
Now I need something similar that acts like this:
- I call the funtion;
- It asks me to select a pline;
- It asks me to select a text;
- It asks me for a filename to export to;
- it writes on the file the selected text;
- It writes on the file the start, mid and final points (i.e. vertexes) of the pline as the routine above.
Thanks in advance.
Solved by aabfm. Go to Solution.
@aabfm wrote:....
Shouldn't be difficult [add a few elements, take out a few], but first, a question:
What do you mean by the "mid" point of a Polyline? Will there always be a vertex that is the middle one? If there might not be [e.g. an open Polyline with 4 vertices or a closed one with 3], what point would you want for the middle? The nearest vertex to halfway? If two are equidistant from there, which one? The always-rounded-up or -rounded-down vertex from halfway, even if another vertex might be closer? Or if you might not always want an actual vertex location, the actual mid-point of the overall length, wherever that falls in relation to vertices? The midpoint of the Polyline segment between the two vertices that split the middle count-wise, regardless of where that falls in relation to the overall length? Etc.
Actualy I just want something that simply returns all the vertex from that pline and afterwards some selected text.
I'm trying to edit the code like this...
(Still haven't finished/tested yet)
(defun c:zi1 ( / f i o s OBJ) (if (and (setq s (ssget '((0 . "LWPOLYLINE")))) (setq f (getfiled "Create Output File" "" "txt" 1)) (setq f (open f "w")) ) (progn (repeat (setq i (sslength s)) (setq o (vlax-ename->vla-object (ssname s (setq i (1- i))))) (princ (apply 'strcat (vl-list* ( (lambda ( a ) (a (vlax-get o 'coordinates))) (lambda ( b ) (if b (cons (strcat "+"(rtos (car b)) "," (rtos (cadr b)) "\t") (a (cddr b)) ) ) ) ) "\t"gostei da li ) ) f ) ) (prompt "n\Select text to export... ") (setq OBJ (ENTSEL)) (setq OBJDATA (entget (CAR OBJ))) (setq TXT (cdr (ASSOC 1 OBJDATA))) (write-line TXT F) (close f) ) ) (princ) ) (vl-load-com) (princ)
I've tried this but without any success
(defun c:zi1 ( / f i o s OBJ OBJDATA TXT nomebase) (setq nomebase (getstring "\nInsira nome base:")) (setq f (strcat "d:\" nomebase "_zi.txt")) (prompt "n\Seleccione o nome da ZI... ") (setq OBJ (ENTSEL)) (setq OBJDATA (entget (CAR OBJ))) (setq TXT (cdr (ASSOC 1 OBJDATA))) (if (and (setq s (ssget '((0 . "LWPOLYLINE")))) (setq f (getfiled "Create Output File" "" "txt" 1)) (setq f (open f "w")) ) (progn (repeat (setq i (sslength s)) (setq o (vlax-ename->vla-object (ssname s (setq i (1- i))))) (princ (apply 'strcat "\n" (vl-list* ( (lambda ( a ) (a (vlax-get o 'coordinates))) (lambda ( b ) (if b (cons (strcat "+"(rtos (car b)) "," (rtos (cadr b)) "\t") (a (cddr b)) ) ) ) ) ) ) f ) (princ TXT f) ) (close f) ) ) (princ) ) (vl-load-com) (princ)
Any idea?...
Just got the solution:
(defun c:zi2 ( / f i o s obj objdata texto texto_f nomebase nome_zi) (setq nomebase (getstring "\nType filename:")) (setq nome_zi (strcat nomebase "_zi.txt")) (setq obj (entsel "\nSelect text to export: ")) (setq objdata (entget (car obj))) (setq texto (cdr (assoc 1 objdata))) (if (and (setq s (ssget '((0 . "LWPOLYLINE")))) (setq f (open nome_zi "w")) ) (progn (repeat (setq i (sslength s)) (setq o (vlax-ename->vla-object (ssname s (setq i (1- i))))) (princ (apply 'strcat (vl-list* "\n" ( (lambda ( a ) (a (vlax-get o 'coordinates))) (lambda ( b ) (if b (cons (strcat "+"(rtos (car b)) "," (rtos (cadr b)) "\t") (a (cddr b)) ) ) ) ) ) ) f ) ) (setq texto_f (strcat "\n=" texto)) (princ texto_f f) (close f) ) ) (princ) ) (vl-load-com) (princ)
