I am looking for a autoLISP that will export text from autocad drawing batch (say 25 drawings) to excel in the following format.
I need rows with drg file name, text and the layer (in which the text is as shown) - below sample rows
Can some one please help me with this one ?
Drg file name text from autocad layer
ARCH1001 TYPICAL TEXT
ARCH1001 Window11 Window_schedule
ARCH1002 CUT BACK TEXT
ARCH1002 Window21 Window_schedule
ARCH1003 6 WELD
ARCH1003 Window31 Window_schedule
ARCH1003 Window32 Window_schedule
ARCH1003 Window33 Window_schedule
ARCH1003 Window34 Window_schedule
Solved by Ajilal.Vijayan. Go to Solution.
Welcome to Autodesk forum.
You can do this DATAEXTRACTION (DX) command
I dont know from which version of autocad it started.
But should work from 2008 series.
Also I am not sure whether this command exists in LT (If you are using LT)
Which version you have ?
