Erasing everything outside a boundary line
CADguy82
CADguy82
I know that AutoCAD has the extreme trim command which enables you to trim everything either inside or outside a boundary line.
Has anyone put together a routine that will delete everything either inside or outside a specified boundary line?
_gile
If it can help, here're some routines.
SelByObj a sub routine to create a selection set with an object (closed pline, circle, ellipse).
SSOW and SSOC 2 examples of using SelbyObj to create selection sets by Window or Crossing
INV_SEL Inverse a selection set.
;;; SelByObj -Gilles Chanteau- 06/10/06
;;; Creates a selection set from an object (circle ellipse or closed
;;; lwpolyline) by Window Polygon or Crossing Polygon.
;;; Arguments :
;;; - ename
;;; - selection mode (Cp or Wp)
;;; - selection filter or nil
(defun SelByObj (ent opt fltr / obj dist n lst prec dist p_lst)
(vl-load-com)
(if (= (type ent) 'ENAME)
(setq obj (vlax-ename->vla-object ent))
(cond
((member (cdr (assoc 0 (entget ent))) '("CIRCLE" "ELLIPSE"))
(setq dist (/ (vlax-curve-getDistAtParam
obj
(vlax-curve-getEndParam obj)
50
n 0
(repeat 50
(setq
lst
(cons
(trans
(vlax-curve-getPointAtDist obj (* dist (setq n (1+ n))))
0
1
lst
(T
(setq p_lst (vl-remove-if-not
'(lambda (x)
(or (= (car x) 10)
(= (car x) 42)
(entget ent)
(while p_lst
(setq
lst
(append
lst
(list (trans (append (cdr (assoc 10 p_lst))
(list (cdr (assoc 38 (entget ent))))
ent
1
(if (/= 0 (cdadr p_lst))
(progn
(setq prec (1+ (fix (* 50 (abs (cdadr p_lst)))))
dist (/ (- (if (cdaddr p_lst)
(vlax-curve-getDistAtPoint
obj
(trans (cdaddr p_lst) ent 0)
obj
obj
(trans (cdar p_lst) ent 0)
prec
n 0
(repeat (1- prec)
(setq
lst (append
lst
(list
(trans
obj
(+ (vlax-curve-getDistAtPoint
obj
0
1
(setq p_lst (cddr p_lst))
(ssget (strcat "_" opt) lst fltr)
;;; Examples (remove space between < and OR or AND):
;;; SSOC Selection by Crossig
(defun c:ssoc (/ ss opt)
(sssetfirst nil nil)
(if (setq ss (ssget "_:S:E"
(list
'(-4 . "< OR")
'(0 . "CIRCLE")
'(-4 . "< AND")
'(0 . "ELLIPSE")
'(41 . 0.0)
(cons 42 (* 2 pi))
'(-4 . "AND>")
'(-4 . "< AND")
'(0 . "LWPOLYLINE")
'(-4 . "&")
'(70 . 1)
'(-4 . "AND>")
'(-4 . "OR>")
(sssetfirst
nil
(ssdel (ssname ss 0) (SelByObj (ssname ss 0) "Cp" nil))
(princ)
;;; SSOW Selection by Window
(defun c:ssow (/ ss opt)
(list
'(-4 . "< OR")
'(0 . "CIRCLE")
'(-4 . "< AND")
'(0 . "ELLIPSE")
'(41 . 0.0)
(cons 42 (* 2 pi))
'(-4 . "AND>")
'(-4 . "< AND")
'(0 . "LWPOLYLINE")
'(-4 . "&")
'(70 . 1)
'(-4 . "AND>")
'(-4 . "OR>")
(sssetfirst nil (SelByObj (ssname ss 0) "Wp" nil))
(princ)
;;; Inv_Sel Inverse a selection set
(defun c:inv_sel (/ ssa ssf n e)
(setq ssa (ssget "_A" '((0 . "~VIEWPORT"))))
(if (setq ssf (cadr (ssgetfirst)))
(repeat (setq n (sslength ssa))
(if (ssmemb (setq e (ssname ssa (setq n (1- n)))) ssf)
(ssdel e ssa)
(sssetfirst)
(sssetfirst nil ssa)
(princ)
) Message was edited by: gile
Gilles Chanteau
GileCAD
GitHub
