Is it possible to create a dynamic block completely from scratch using Lisp?
I also want the ability to be able to create different dynamic block geometry depeding on the Visibility parameter.
I seem to be able to create the normal (non-dynamic) block geometry using Lisp but cannot seem to find out a way to enter the block editor and create stuff pertaining to dynamic blocks.
I have 1000's of dynamic blocs to create and looking to a way to automate this using Lisp.
Any clues? Any help is appreciated. Thanks in advance.
Regards
Rakesh Rao
I am not sure but I seriously doubt that lisp could be used to build a dynamic block. The whole idea of a dynamic block is that it is easily built by a drafter and can substitute for thousands of ordinary blocks.
I am not sure why you would need thousands of programmatically created dynamic blocks but if you are that into programmatically creating blocks, why make them dynamic?
Try the .NET newsgroup. There might be more chance of a programmatic solution there.
