Visual LISP, AutoLISP and General Customization
Active Member
cadster
Message 1 of 3 (68 Views)
ERROR -> Menu Syntax Error Line: ###
68 Views, 2 Replies
08-22-2000 08:48 AM
I have a custom menu for it that has been massaged forward from release 10 through all releases of AutoCAD to 2000. One of the problems I have run into in the last couple of versions of AutoCAD is what appears to be a limit of the length or size of a consecutive set of commands. It appears to be about 33 to 34 lines of code. Is there a limit to the length or amount of characters a section of a custom menu can deal with? And if so, is there a way around it? This message appears when you load the menu that has this problem: ERROR -> Menu Syntax Error Line: ###. Any Ideas other than shortening?
*DASeibert
Message 2 of 3 (68 Views)
Re: ERROR -> Menu Syntax Error Line: ###
08-22-2000 09:23 AM in reply to: cadster
Since you don't want to hear about shortening your menu
routines, I'm not gonna say it.
However, anything that takes more than (2) two lines in a menu
file  just begs to be in it's own program file.
I kinda understand why you would do such a thing (keeping all
your customizations in one place and all) but it really is not a good
idea.
A lot of what you are probably doing could be done in that
*.mnl file that goes with your menu and then you could just call it from your
menu.  This would also keep things nice and neat for you.
Your trying to do more (IMO) than what the menu is intended to
do.
Have fun,
Dave
I
shortening?
Active Member
cadster
Message 3 of 3 (68 Views)
Re:
08-22-2000 11:53 AM in reply to: cadster
You are absolutly right, I guess i should just put it in my mnl file. Thank you for your reply.
You are not logged in.
Announcements
Need installation help?
Ask the Community
