Need help looking for a Lisp. Situation is, I download GIS road centerlines, which are poly lines. Then offset the road centerline to each side and then trim at the intersections. Want a lisp where I enter the offset to each side, then allow me to select multiple lines, and trim lines that intersect. Have found simple one that I have to select each line individually and trim manually, Looking for something to speed it up.
Try this code to speed up, not sure about how it will be work on your release
(defun C:geof (/ *error* acsp adoc clon clon1 clon2 delobjs fcode fdata fuzz gap pfs pline_objs ssunion1 ssunion2 un1lst un2lst x) ;; fixo 2014 (vl-load-com) (defun *error* (msg) (vla-endundomark (vla-get-activedocument (vlax-get-acad-object))) (if (> (length delobjs) 0) (progn (foreach obj delobjs (vl-catch-all-apply 'vla-delete (list obj))))) (princ) ) (setq adoc (vla-get-activedocument (vlax-get-acad-object)) acsp (vla-get-block (vla-get-activelayout adoc))) (setq pfs (vla-get-pickfirstselectionset adoc) ) (vla-startundomark (vla-get-activedocument (vlax-get-acad-object))) (prompt "\nSelect centerlines: ") ;; clean up selection (vl-catch-all-apply 'vla-clear (list pfs)) ;; add desired layer name to filter exclusively centerlines, optional (setq fcode (vlax-safearray-fill (vlax-make-safearray vlax-vbinteger '(0 . 6)) (list -4 -4 0 70 -4 410 -4) ) fdata (vlax-safearray-fill (vlax-make-safearray vlax-vbvariant '(0 . 6)) (list "<and" "<and" "lwpolyline" 0 "and>" (getvar "ctab") "and>")) ) (vla-selectonscreen pfs fcode fdata) (if (> (vla-get-count pfs) 0) (progn (initget 6) (setq gap (getdist "\nWhole road width: ")) (setq fuzz (* 0.025 gap)); increment peditgap to suit (setq gap (/ gap 2)) (vlax-for obj pfs (setq clon (vl-catch-all-apply 'vla-copy (list obj ))) (vl-catch-all-apply 'vla-put-color (list clon 1)) (setq delobjs (cons clon delobjs))) (foreach obj delobjs (setq clon1 (car (vlax-safearray->list (vlax-variant-value(vla-offset obj gap))))) (vl-catch-all-apply 'vla-put-layer (list clon1 "0")) (vl-catch-all-apply 'vla-put-linetype (list clon1 "Continuous")) (vl-catch-all-apply 'vla-put-color (list clon1 1)) (setq un1lst (cons clon1 un1lst)) (setq clon2 (car (vlax-safearray->list (vlax-variant-value(vla-offset obj (* -1 gap)))))) (vl-catch-all-apply 'vla-put-layer (list clon2 "0")) (vl-catch-all-apply 'vla-put-linetype (list clon2 "Continuous")) (vl-catch-all-apply 'vla-put-color (list clon1 1)) (setq un2lst (cons clon2 un2lst)) ) (setq ssunion1 (ssadd)) (mapcar '(lambda (x)(ssadd x ssunion1))(mapcar 'vlax-vla-object->ename un1lst)) ;(initcommandversion) (vl-cmdf "_.pedit" "_M" ssunion1 "" "_J" fuzz "") (princ "\nproc 3") (setq ssunion2 (ssadd)) (mapcar '(lambda (x)(ssadd x ssunion2))(mapcar 'vlax-vla-object->ename un2lst)) ;(initcommandversion) (vl-cmdf "_.pedit" "_M" ssunion2 "" "_J" fuzz "") ;; clean up memory (if (> (length delobjs) 0) (progn (foreach obj delobjs (vl-catch-all-apply 'vla-delete (list obj))))) (vla-regen adoc acActiveViewport) (princ "\nCommand end\n") ) ) (princ) )
I think you have do following
Add this lisp from attachment in TrustedPaths folder, see in Options->Files tab etc
Then use Appload and add this file in Contenst-> Start up
Reload Acad then try again, just tested it in A2014 on my end,
all is working good for me (although I've used russian settings on
my Windows 7)
