Active Contributor pli
Active Contributor
pli
Message 1 of 6 (345 Views)
Does XREF/BLOCK have Boundary
345 Views, 5 Replies
12-02-2010 11:23 AM
How can you test if an Xref or Block Insert has been xclipped with a Boundary?
I don't see any difference in the 70 or 71 flags.
Thanks.
Paul Li
Senior Associate
ALTOON PARTNERS LLP
Los Angeles • Amsterdam • Shanghai • Hong Kong • Moscow
444 South Flower Street • 48th Floor • Los Angeles • California • 90071-2901
D +1 213 225 1944 • T +1 213 225 1900 • www.altoonpartners.com
t.willey
Message 2 of 6 (338 Views)
Re: Does XREF/BLOCK have Boundary
12-02-2010 02:13 PM in reply to: pli
This should work.  Haven't used it since I wrote it, as it wouldn't work for what I wanted, but it will return the boundry of a xclip if it has one.
(defun GetSpatialFilter (ename / Data Dict tempDict)
    ; Get the xclip boundry
    (if
        (and
            (setq Data (entget ename))
            (setq Dict (cdr (assoc 360 Data)))
            (setq tempDict (dictsearch Dict "ACAD_FILTER"))
            (setq tempDict (dictsearch (cdr (assoc -1 tempDict)) "SPATIAL"))
        (cons '(0 . "SPATIAL_FILTER") (member (assoc 100 tempDict) tempDict))
Active Contributor
pli
Message 3 of 6 (336 Views)
12-02-2010 02:18 PM in reply to: t.willey
Thanks this works perfectly.
As a side note, can the same be used to test if a clip boundary exists for Image, DGN, DWF, PDF ?
Paul Li
Senior Associate
ALTOON PARTNERS LLP
t.willey
Message 4 of 6 (332 Views)
12-02-2010 02:33 PM in reply to: pli
Don't know.  Don't really work with them, but I would think that you could test them with the program, and see what is returned.  It wouldn't harm any entity, as it is just looking at stuff.
You're welcome.
Active Contributor
pli
Message 5 of 6 (329 Views)
12-02-2010 02:41 PM in reply to: t.willey
Nope, your routine did not work for the other object types.  Too bad.  Thanks anyways.
Paul Li
Senior Associate
ALTOON PARTNERS LLP
t.willey
Message 6 of 6 (325 Views)
12-02-2010 03:13 PM in reply to: pli
Looks like for images you have to look at dxf codes 13 ( size of the image ) and 14 ( points of clipping ) and compare them, because even when I inserted an image, it has dxf codes 14, so it seems they are always clipped.  But if code 91 is greater than 2, then there is some real clipping for sure, but the clipping could be the whole size of the image.
You are not logged in.
Ask the Community
