Does Drawing contain an Image
4 REPLIES 4
petervose
141 Views, 4 Replies
I'm trying to return a list of loaded images on a drawing, but failing. If someone could point me in the right direction it would be greatly appreciated.
Thanks Peter
4 REPLIES 4
in reply to: petervose
(defun getImagePaths (/ data paths)
(if (setq data (dictsearch (namedobjdict) "acad_image_dict"))
(foreach item data
(if (= 350 (car item))
(setq
paths (cons (cdr (assoc 1 (entget (cdr item)))) paths)
paths
(defun c:dwgOk (/ data item)
(if (setq data (getImagePaths))
(if
(and
(= 1 (length data))
(setq item (car data))
(equal
(strcase
(strcat
(vl-filename-directory item)
(vl-filename-base item)
(strcase
(strcat
(getvar "dwgprefix")
(vl-filename-base (getvar "dwgname"))
(princ
"\nFILENAME AND IMAGENAME MATCH"
(princ
(alert
"\nMORE THAN ONE IMAGE IS ATTACHED OR\nTHE FILENAMES/PATHS ARE NOT THE SAME"
(princ "\nno images attached")
(princ)
petervose
That's exactly what I was after - Thanks very much for the quick response and the code.
Peter
You're welcome.........and thanks to Jason Piercey for helping out with the code. 🙂
Peter, If the name of the image is of any interest, take a look at the thread "Image detach using lisp" 2/18/2004. My last post there. Joe Burke "petervose" wrote in message news:21291556.1077646533693.JavaMail.jive@jiveforum1.autodesk.com... > I'm trying to return a list of loaded images on a drawing, but failing. If someone could point me in the right direction it would be greatly appreciated. > Thanks Peter
”Boost
