Visual LISP, AutoLISP and General Customization
Display Colours
3 REPLIES 3
205 Views, 3 Replies
Display Colours
Rather than going Tools > Preferences > Display > Colours.... I would like
to change the screen display from blck to white or white to black
backgrounds with a script on the toolbars....
Any help you can give would be useful...
Many thanks
3 REPLIES 3
This is basically the same thing, but also toggles the crosshair color.
Don
"Lizzy" wrote in message
news:2E5B5A0A77F34ABBCD9E97557521701A@in.WebX.maYIadrTaRb...
> Many thanks
Sorry, put in the wrong PaperSpace test.
Don
"DonB" wrote in message
news:271D206435A2A0F396BA571ECFCB3773@in.WebX.maYIadrTaRb...
> Don
like
> > Many thanks
(defun c:ToggleScreenColor (/ dcolor newcol crosscol prefdisplay)
(vl-load-com)
(setq prefDisplay (vla-get-display (vla-get-Preferences
(vlax-Get-Acad-Object))))
(vla-get-Display AppPreferences)
(if (is-paper)
(setq dColor
(vlax-variant-value
(vlax-variant-change-type
(vla-get-GraphicsWinLayoutBackgrndColor prefDisplay)
vlax-vbLong
(setq dColor
(vlax-variant-value
(vla-get-GraphicsWinModelBackgrndColor prefDisplay)
vlax-vbLong
(setq newcol (vlax-make-variant (if (= dColor 0) 16777215 0) vlax-vbLong))
(setq crosscol (vlax-make-variant (if (= dColor 0) 0 16777215) vlax-vbLong))
(if (is-paper)
(progn
(vla-put-GraphicsWinLayoutBackgrndColor prefDisplay newcol)
(vla-put-LayoutCrosshairColor prefDisplay crosscol)
(progn
(vla-put-GraphicsWinModelBackgrndColor prefDisplay newcol)
(vla-put-ModelCrosshairColor prefDisplay crosscol)
;;;IS-PAPER returns T if in NON-FLOATING PaperSpace
;;;ELSE nil for floating or complete ModelSpace
;;;Example (if (is-paper) )
(defun is-paper ()
(cond
((and (= (getvar "tilemode") 0)(/= (getvar "cvport") 1))nil)
((and (= (getvar "tilemode") 0)(= (getvar "cvport") 1))t)
(t nil)
I suspect you wish to do this for when you cut/paste from Autocad and you
don't want the black background.
The following tip, from Ken Alexander, sets the background to transparent
for cut/past operations.
Jon
From Ken ->
Try using the wmfbkgnd system variable setting.
0 makes the background transparent
1 makes the background color the same as the autocad
current background color.
Ken Alexander
Acad2000
Win2000prof.
> Many thanks
”Boost
