Valued Mentor
mdhutchinson
Message 1 of 11 (238 Views)
Disabled XRefEdit work around
238 Views, 10 Replies
06-14-2013 01:29 AM
I am looking for an alternative to in place XRef Edit.
The third party software I am stuck with has disabled in place editing an Xref.
The specific application I need is to allow the user to move an intelligent room tag that is XReffed into discipline specific models. Disciplines are Architectural, Mechanical, Electrical..Etc. Each discipline has their own room tag and needs to move their own tag to a location that can be clearly seen on their finished plot. Xref edit in place is the perfect tool for this..But since the third party has disabled the command, I need an alternative method.
Anyone have any ideas?
Valued Mentor
alanjt_
Message 2 of 11 (211 Views)
Re: Disabled XRefEdit work around
06-14-2013 11:15 AM in reply to: mdhutchinson
Are you talking about refedit?
If it's disabled, just prefix a command with a period and it *should* work. Granted, there may be a good reason the 3rd party software disables it.
Valued Mentor
mdhutchinson
Message 3 of 11 (206 Views)
06-14-2013 11:52 AM in reply to: alanjt_
Yes... refedit
(I was away from the office when I did the post.)
I've already tried prefixing the command with a period... still get message that the command was disabled by the software.
They've sown this up pretty good. I tried launching AutoCAD with out the 3rd party software running... and still get the message that it was dissabled.
It would be nice if I could discover how to re-inable the command, however, what I was hoping to find was just another method of doing what I need (as if refedit worked).  Kind of like opeing the desired xref and xreffing in the other files just as they were xreffed in the oposite file.  Kind of like this:
Main dwg file A
XRefB
XRefC
XRefD
I want to edit the XRefB for instance
So Open XRefB for editing... and XReffing the others back in...
XRefC
XRefD
XRefA
scot-65
Message 4 of 11 (198 Views)
06-14-2013 03:01 PM in reply to: mdhutchinson
(command ".redefine" "xrefedit")
Scot-65
Dyslexia is a permanent physical disability that cannot be seen.
Valued Mentor
alanjt_
Message 5 of 11 (193 Views)
06-14-2013 05:35 PM in reply to: scot-65
*refedit.
Valued Mentor
mdhutchinson
Message 6 of 11 (159 Views)
06-17-2013 06:23 AM in reply to: alanjt_
So what is...  *refedit?
refedit with a leading asterisk yeilds only unknown command.
I said that I have already tried refedit with a leading period. I know that a leading period calls the command even though it has been redefined. However, the 3rd part software has went to some measures beyond simply redefining the command. So... what is it that you mean by *refedit?
let me see if I can explain...
The third party developer has disabled the refedit command... so much so that all that you suggest DOES NOT WORK!
So, what I need is some alternative way to edit the xref in a way that I can see all the surronding geometry as I would if I could use refedit. Open the xref that I want to edit, then xref in all the other dwgs. A lisp to do this would be great!.
Valued Mentor
alanjt_
Message 7 of 11 (157 Views)
06-17-2013 06:27 AM in reply to: mdhutchinson
No, the asteric was signifiying that I was offering an edit to the above post, since XREFEDIT was typed in for redefiing, rather than REFEDIT.
Valued Mentor
mdhutchinson
Message 8 of 11 (149 Views)
06-17-2013 06:50 AM in reply to: alanjt_
ooh... I see...
either way... redefing the refedit command back to AutoCAD's internal .refedit does not work in this case. See the attached.
Distinguished Mentor
BlackBox_
Message 9 of 11 (146 Views)
06-17-2013 06:55 AM in reply to: mdhutchinson
I am curious to know... Have you tried directing any/all of this opinionated commentary toward the manufacturer of this 3rd party software, instead of expressing your frustration(s) here?
Also, FWIW - The .NET API makes it quite simple to Veto any command one wants.
As an example, I coded a quick plug-in for someone who wanted (when in the Block Editor) to Veto() the QUIT Command, in the event that users accidentally select the "X" to quit the session in liue of the Block Editor... So the plug-in registered a Command Event handler which monitored for QUIT following BEDIT, and if QUIT was invoked, QUIT was Veto()-ed, and BCLOSE was invoked in it's place, thus removing the Event handler.
/Example
"Potential has a shelf life." - Margaret Atwood
Autodesk Exchange Apps ~ Autoloader ~ AutoCAD Security
Valued Mentor
mdhutchinson
Message 10 of 11 (131 Views)
06-17-2013 07:21 AM in reply to: BlackBox_
/Example
ooh, Yes I have spoken with the developer (I've been told that I am some what of a pit bull when it comes to such encounter's... however, I've also been told that I have pushed back and finally gotten attention... and that it has resulted in improving the product.
It does look obvious that the 3 rd party developer has put an Event Handler in place.
"thus removing the Event handler." ...  Are you saying that it is possible I could override in some way via .Net?
You are not logged in.
Ask the Community
