Searching around for this answer the closest that I found is: Layout preview thumbnails problems
The thread seems to dance all around the issue without answering and the OP did not return to asnwer the inquiry.
I use many pages in my dwt and that means I have tabs running all the way along the bottom of the screen. Everytime my mouse passes over one of these tabs I get the thumbnail preview pop up in the way of the work I'm doing. I have tried to ingore it for a looong time, but, if it is possible to disable those previews from appearing unintentionally, then please tell me how to disable them.
Thank you.
( AutoCAD 2013 64bit )
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
FILETABPREVIEW only throws an error.
"Unknown command" AC2013
everything I find through google says there is an option in CIVIL but no mention for AutoCAD. ?
Scot-65
