Visual LISP, AutoLISP and General Customization
662 Views, 4 Replies
Dimvars
Yo,
Where can I "quickly" find a list (online) of all the Dimvars with brief
explainations and possible setting ranges. I have the Latest DXF
documentation but it only lists the var names.
BW
4 REPLIES 4
Command Reference, System Variables.
R. Robert Bell, MCSE
www.AcadX.com
"Bill Wallace" wrote in message
news:61B8A1F7553E8B7C7BCF8009F79396E5@in.WebX.maYIadrTaRb...
| Yo,
| BW
kevin
Type in:
SETVAR then ? for the complete list of all setvars.
Here's what mine looks like;
DIMADEC 0
DIMALT OFF
DIMALTD 2
DIMALTF 0.3048
DIMALTRND 0.0000
DIMALTTD 2
DIMALTTZ 0
DIMALTU 2
DIMALTZ 0
DIMANNO 0 (read only)
DIMAPOST "m"
DIMARCSYM 0
DIMASO ON
DIMASSOC 2
DIMASZ 0.1100
DIMATFIT 3
DIMAUNIT 0
DIMAZIN 0
DIMBLK ""
DIMBLK1 ""
DIMBLK2 ""
DIMCEN 0.0200
DIMCLRD 2
DIMCLRE 2
DIMCLRT 2
DIMDEC 2
DIMDLE 0.0000
DIMDLI 0.3800
DIMDSEP "."
DIMEXE 0.0300
DIMEXO 0.0600
DIMFIT 3
DIMFRAC 0
DIMFXL 1.0000
DIMFXLON OFF
DIMGAP 0.0300
DIMJOGANG 45d0'0"
DIMJUST 0
Press ENTER to continue:
DIMLDRBLK ""
DIMLFAC 1.0000
DIMLIM OFF
DIMLTEX1 ""
DIMLTEX2 ""
DIMLTYPE ""
DIMLUNIT 2
DIMLWD -1
DIMLWE -1
DIMPOST "'"
DIMRND 0.0000
DIMSAH OFF
DIMSCALE 20.0000
DIMSD1 OFF
DIMSD2 OFF
DIMSE1 OFF
DIMSE2 OFF
DIMSHO ON
DIMSOXD OFF
DIMSTYLE "Standard" (read only)
DIMTAD 1
DIMTDEC 2
DIMTFAC 1.0000
DIMTFILL 0
DIMTFILLCLR 0
DIMTIH OFF
DIMTIX OFF
DIMTM 0.0000
DIMTMOVE 0
DIMTOFL OFF
DIMTOH OFF
DIMTOL OFF
DIMTOLJ 1
DIMTP 0.0000
DIMTSZ 0.0000
DIMTVP 0.0000
DIMTXSTY "L120"
DIMTXT 0.1200
DIMTXTDIRECTION OFF
DIMTZIN 0
DIMUNIT 2
DIMUPT OFF
DIMZIN 0
end.
I created a script file to quickly load my preferences call "Dimen.lsp".
It is executed by (load"dimen") as long as; files settings in "Options" "Files" "Support" have a known path subdirectory to the folder (so it can find the lisp file).
Best of luck.
Kent1Cooper
in reply to: kevin
[Wow -- 20 years after the initial post!]  That list may be good, but doesn't include the brief explanations and options asked for in Message 1.  How similar these things are now to what they were then, I couldn't say [certainly many are the same], but today, >this< would answer that request.  It has all System Variables starting with D, so more than they were asking for, but at least includes all the DIM* ones together, with not only short descriptions right there, but you can pick on each to get to the options, defaults, etc.
Kent Cooper, AIA
Sea-Haven
in reply to: Kent1Cooper
This is not complete but can be useful just for dims, forget where I found it.
(cons 0 "DIMSTYLE")
(cons 100 "AcDbSymbolTableRecord")
(cons 100 "AcDbDimStyleTableRecord")
(cons 2 Dim_Name) ;Dim style name
(cons 70 0) ; Standard flag
(cons 3 " [m]"); DIMPOST
(cons 4 ""); DIMAPOST
(cons 5 DIMBLK-Name) ;DIMBLK-Name of block instead of default arrowhead
(cons 6 DIMBLK-Name);(cons 6 "ClosedFilled"); DIMBLK1
(cons 7 "");(cons 7 DIMBLK-Name); DIMBLK2
(cons 170 0) ;DIMALT-turns off alternate units
(cons 40 dimscale) ;DIMSCALE-sets the overall scale factor applied to all dimensions
(cons 41 Arrow_Size) ;DIMASZ-sets the size of the arrow/tick
(cons 42 Extension_Line_Origin_Offset); DIMEXO
(cons 43 Dimension_Line_Spacing); DIMDLI
(cons 44 Extension_Above_Dimension_Line) ;DIMEXE-specifies how far to extend the extention line beyound the dim line
(cons 45 0.0); DIMRND
(cons 46 0) ;DIMDLE-sets the distance the dimension line extends beyond the extension line
(cons 47 0.0); DIMTP
(cons 48 0.0); DIMTM
(cons 71 0); DIMTOL
(cons 72 0); DIMLIM
(cons 73 0) ;DIMTIH-controls the position of dimension text inside extention lines ;METTE IL TESTO DI QUOTA ORIZZONTALE
(cons 74 0) ;DIMTOH-controls the position of dimension text outside extention lines
(cons 75 1); DIMSE1 ;1 sopprime la linea di estensione, 0 la lascia
(cons 76 1); DIMSE2 ;1 sopprime la linea di estensione, 0 la lascia
(cons 77 1) ;DIMTAD-controls the vertical position of text in relation to the dim line
(cons 78 3) ;DIMZIN-controls the suppression of zeros
(cons 79 1); DIMAZIN
(cons 140 Text_Height) ;DIMTXT-specifies the height of the text in the dim
(cons 141 Center_Mark_Size); DIMCEN
(cons 142 0.0); DIMTSZ
(cons 143 0.5) ;DIMALTF-controls the scale factor for alt. units
(cons 144 quote_scale); DIMLFAC ;scala di quota
(cons 145 0.0); DIMTVP
(cons 146 0.64); DIMTFAC
(cons 147 Gap_From_dimension_Line_to_Text) ;DIMGAP-sets the distance from around the dim text
(cons 170 0); DIMALT
(cons 171 2) ;DIMALTD-controls the decimal places for units
(cons 172 0) ;DIMTOFL-forces a line inside extension lines
(cons 173 1); DIMSAH
(cons 174 0); DIMTIX
(cons 175 0); DIMSOXD
(cons 176 256); DIMCLRD
(cons 177 256); DIMCLRE
(cons 178 256); DIMCRRT DIMCLRT color of text
(cons 179 0); DIMADEC
(cons 270 2) ;DIMUNIT-sets the units format for all dims ;2 decimale ; 4architettonico
(cons 271 Decimal_Places) ;DIMDEC-sets the number of decimal places of primary units
(cons 272 Tolerance_Decimal_places); DIMTDEC
(cons 273 2) ;DIMALTU-sets the units for alt. units
(cons 275 0) ;DIMAUNIT-sets the angular format for angular dims
(cons 276 1); DIMFRAC
(cons 277 2); DIMLUNIT ;2 decimale ; 4architettonico
(cons 278 0); DIMDSEP
(cons 279 Text_Movement); DIMTMOVE
(cons 280 0) ;DIMJUST-controls the horizontal positioning of dim text
(cons 281 -1); DIMSD1
(cons 282 -1); DIMSD2
(cons 283 1); DIMTOLJ
(cons 284 3); DIMTZIN
(cons 285 1); DIMALTZ
(cons 286 0) ;DIMALTTZ-Toggles the suppression in tolerance values
;(cons 287 0); DIMFIT
;(cons 288 0); DIMUPT
;(cons 289 0); DIMATFIT
(cons 340 (tblobjname "style" "Estilo_Cotas")); DIMTXSTY
;(cons 341 (cdr (assoc 330 (entget (tblobjname "block" "."))))); DIMLDRBLK
;(cons 342 (cdr (assoc 330 (entget(tblobjname "block" "_Oblique"))))); DIMBLK must setvar dimblk 1st
;(cons 343 (cdr (assoc 330 (entget(tblobjname "block" "_Oblique"))))); DIMBLK1
;(cons 344 (cdr (assoc 330 (entget(tblobjname "block" "_Oblique"))))); DIMBLK2
;(cons 371 -2); DIMLWD
;(cons 372 -2); DIMLWE
(entmake ds)
”Boost
