Visual LISP, AutoLISP and General Customization
Dimension text fill color - LISP
5 REPLIES 5
1758 Views, 5 Replies
I would like to set dimension text fill color to "background" instead of, you know, dimensioning my drawings properly.
I have this code I got on these forums and it works well except for the 'TextFillColor' variable. I can't find the correct color number or syntax for "Background'. It's currently set to 0 which produces ByBlock, and any number I put in there corresponds to the AutoCAD color number (1 = Red, 2 = Yellow, etc.)
If you have a better routine that you could post that works for me too. Or maybe you could just do my work for me? Even better.
Thanks in advance for you help.
(defun c:test (/ obj num cnt)
(vl-load-com)
(setq ss1 (ssget '((0 . "Dimension")))
num (sslength ss1)
cnt 0)
(repeat num
(setq obj (vlax-ename->vla-object (ssname ss1 cnt)))
(vlax-put-property obj 'TextFill :vlax-true)
(vlax-put-property obj 'TextFillColor 0)
(setq cnt (1+ cnt))
(vl-cmdf "_draworder" ss1 "" "f")
5 REPLIES 5
hmsilva
Maybe something like this
(defun c:test (/ CNT ENT ENTDATA NEWENTDATA NUM SS1)
  (vl-load-com)
	num (sslength ss1)
	cnt 0
  (repeat num
    (setq ent (entget (ssname ss1 cnt)))
    (setq entdata '((-3 ("ACAD" (1000 . "DSTYLE") (1002 . "{") (1070 . 69) (1070 . 1) (1002 . "}")))))
    (setq newentdata (append ent entdata))
    (entmod newentdata)
    (setq cnt (1+ cnt))
HTH
Henrique
Awesome! Thanks!
hmsilva
@Anonymous wrote:
Awesome! Thanks!
You're welcome, VFW1968
glad I could help
Henrique
pbejse
in reply to: hmsilva
HTH
Henrique
Nice Henrique Smiley Happy
hmsilva
in reply to: pbejse
Thank you! pbejse
Cheers
Henrique
”Boost
