*Isaacs, Woody
Message 1 of 4 (33 Views)
Dialog Boxes.
33 Views, 3 Replies
01-28-2000 01:13 PM
I have developed a DCL and lisp code for a simple dialog box with one toggle
and a column of radio buttons. I am experienced in lisp but this is my
first time creating a dialog. I have reviewed the Autodesk information
regarding callbacks but can't seem to get it right. Could anyone provide
lisp code for a simple DCL to help steer me in the right direction in terms
of the required callbacks and ending the dialog? I would most appreciate
it.
*Tovar, Rudy
Message 2 of 4 (33 Views)
Re: Dialog Boxes.
01-28-2000 02:18 PM in reply to: *Isaacs, Woody
Hello Woody.
Sample Lisp for dcl call below
; Lisp Skeleton for Dialog: sample
(defun C:sample (/ dcl_id)
(setq dcl_id (load_dialog "C:\\sample.dcl"))
(if (not (new_dialog "sample" dcl_id)) (exit))
(action_tile "accept" "(done_dialog)")
(action_tile "cancel" "(done_dialog)")
(start_dialog)
(unload_dialog dcl_id)
(princ)
(defun default_action (key)
(alert (strcat "The key for the tile selected is \n\"" key "\""))
(princ "Function Name(s) defined: sample ")
(princ)
Sample.dcl listed below
dcl_settings : default_dcl_settings { audit_level = 3 ; }
sample : dialog {
label = "Sample" ;
ok_cancel ;
Rudy@whainc.com
"Automation Equal Imagination..." - "Automating Success"
Programmer/Developer/MIS Assist.
www.wharchitects.com
Woody Isaacs wrote in article
<86t0ga$nnl24@adesknews2.autodesk.com>...
toggle
terms
> it.
*Georgescu, Sorin
Message 3 of 4 (33 Views)
Re: Dialog Boxes.
01-28-2000 02:22 PM in reply to: *Isaacs, Woody
You'l find an example of lisp code and dcl file in the attached files. They
are not exactly what you need
but it works and maybe it will help you with the relation between the lsp
and the associated dcl file. See
the key attribute of the element in the dcl file and the corresponding
get_tile function in the lsp file.
Sorin
"Woody Isaacs" wrote in message
news:86t0ga$nnl24@adesknews2.autodesk.com...
toggle
terms
> it.
*Doerr, Michael
Message 4 of 4 (33 Views)
Re: Dialog Boxes.
01-30-2000 10:57 PM in reply to: *Isaacs, Woody
Hi Woody,
there is a very good tutorial about dialogue boxes at "afralisp":
http://afralisp.hypermart.net/tutor.htm
Look at "dialogue boxes step by step".
Hope this helps,
Michael
Woody Isaacs schrieb in Nachricht <86t0ga$nnl24@adesknews2.autodesk.com>...
toggle
>it.
You are not logged in.
Ask the Community
