Detach image without prompt
1 REPLY 1
531 Views, 1 Reply
I'm using some code I found on forums to detach unreferenced image from DWG files - however the code requires the user to say "yes" at a user prompt, which I can't have (I'll be cycling through thousands of files).
Can anyone help find a way to remove the user prompt?   Here's the code I got from a forum:
 (defun remlst (/ tmp1)
  (setq
    tmp (length (member (cdr (assoc 340 (entget delent))) enamelst))
  (repeat (- (length symlst) tmp)
    (setq tmp1 (cons (car symlst) tmp1))
    (setq symlst (cdr symlst))
  (setq tmp (list (car symlst)))
  (setq symlst (append (reverse tmp1) (cdr symlst)))
 (defun massoc (key alist / x nlist)
  (foreach x alist
    (if (eq key (car x))
      (setq nlist (cons (cdr x) nlist))
  (reverse nlist)
  (vl-load-com)
  (setq ss1 (ssget "x" '((0 . "IMAGE"))))
  (setq ctr 0)
  (setq id (dictsearch (namedobjdict) "acad_image_dict"))
  (setq symlst (massoc 3 id))
  (setq enamelst (massoc 350 id))
  (if ss1
    (progn
      (while (< ctr (sslength ss1))
 (setq delent (ssname ss1 ctr))
 (setq vl_delent (vlax-ename->vla-object delent))
 (setq ipath (vla-get-ImageFile vl_delent))
 (remlst)
 (setq iname (strcat (vl-filename-base ipath) (vl-filename-extension ipath)))
 (if (and (not (findfile ipath))
   (not (findfile iname))
   (progn
     (dictremove (cdr (car id)) (car tmp))
     (append tmp symlst)
     (ssdel delent ss1)
        (setq TextLine (strcat filepath filename " <---> " iname))
    (write-line TextLine logfilename)
 (vla-delete vl_delent)
   (progn
     (setq ctr (1+ ctr))
  (while symlst
    (dictremove (cdr (car id)) (car symlst))
Tags (3)
1 REPLY 1
scot-65
Since I had help on this matter a few years ago, I will post what I have.
   ;*** AUTOMATICALLY REMOVE ALL UNREFERENCED IMAGES *** 5-5-07
   (if (and (setq dict (dictsearch (namedobjdict) "ACAD_IMAGE_DICT"))
            (assoc 350 dict) );and
    (progn
     (setq lst nil)
     (if (setq ss1 (ssget "X" (list (cons 0 "IMAGE"))))
      (progn
       (princ "\n Removing Unreferenced Images.")
       (setq n 0)
       (repeat (sslength ss1)
       	(setq lst (cons (cdr (assoc 340 (entget (ssname ss1 n)))) lst)
              n (1+ n))
       );repeat
      );progn
     );if
     (setq n nil)
     (while (setq n (tblnext "BLOCK" (not n)))
      (setq ss1 (cdr (assoc -2 n)))
      (while ss1
       (if (= (cdr (assoc 0 (setq elst (entget ss1)))) "IMAGE")
        (setq lst (cons (cdr (assoc 340 elst)) lst)) );if
       (setq ss1 (entnext ss1))
      );while
     );while
     (foreach n dict
      (if (and (= (car n) 350) (not (member (cdr n) lst)))
       (entdel (cdr n)) );if
      );foreach
    );progn
   );if
   (setq dict nil ss1 nil n nil lst nil elst nil)
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
”Boost
