aqdam1978
Message 1 of 11 (616 Views)
Delete specific Block
616 Views, 10 Replies
02-13-2013 08:28 PM
I need to delet a specific block from current opened drawing by LISP command.
for example removing XREF attached is very easy:
(COMMAND "-XREF" "D" "FRAME")
I can remove "FRAME" XREF from drawing.
Now, I want to delete a/all block with "TB12" name with same action!
(command "BlockDelete" "TB12")
so, how can I delete a/all block with specific name in current drawing?
pbejse
Message 2 of 11 (604 Views)
Re: Delete specific Block
02-13-2013 11:25 PM in reply to: aqdam1978
Is that a new autocad command on newer vestions? or are you wanting a code to behave the way a "BlockDelete" command if it does exists?
hmsilva
Message 3 of 11 (591 Views)
02-14-2013 01:56 AM in reply to: aqdam1978
perhaps something like
;; usage (delblk "blkname1,blkname2,blkname3,and_so_on")
(defun delblk (blkname / ss)
(if (setq ss (ssget "x" (list (cons 0 "INSERT") (cons 2 blkname))))
(progn
(command "-layer" "_U" "*" "")
(command "erase" ss "")
(command "layerp")
(command ".purge" "b" blkname "n")
);; progn
);; if
(princ)
change the name to "BlockDelete" if you want
hope that helps
Henrique
pbejse
Message 4 of 11 (582 Views)
02-14-2013 02:37 AM in reply to: hmsilva
(defun DelBlk  (lst / aDoc n)
  (setq n 0 aDoc (vla-get-activedocument (vlax-get-acad-object)))
  (vlax-for layout  (vla-get-layouts aDoc)
    (vlax-for i  (vla-get-block layout)
      (if (and
            (eq (vla-get-ObjectName i) "AcDbBlockReference")
            (member (strcase (vla-get-effectivename  i))(mapcar 'strcase lst))
            (not (vl-catch-all-error-p (vl-catch-all-apply 'vlax-invoke (list i 'Delete)))))
            	(setq n (1+ n))
  (repeat 4
  (vla-purgeall aDoc)
  (princ (strcat "\n" (itoa n)  " Objects deleted"))
  (princ)
HTH
EDIT:  USAGE
 (Delblk '("block1" "block2"))
hmsilva
Message 5 of 11 (569 Views)
02-14-2013 02:56 AM in reply to: pbejse
pbejse,
nice code, works in all layouts too, mine don't...
And if the blocks are in locked layers?
Cheers
Henrique
pbejse
Message 6 of 11 (563 Views)
02-14-2013 03:28 AM in reply to: hmsilva
hmsilva wrote:
pbejse,
Thats always a problem when using the command alternative. it can only process the current tab. sometimes even entdel is acting up during iteration. as you well know entdel will also "restore" so i ended up with VL.
Cheers
Henrique
You got me there Henrique :smileyhappy: Good point.
If you notice I  use vl-catch-error-p instead of unlocking layers at the get-go and restoring at the end. I had a discussion before wether to unlock a layer during runtime. The prevalent answer is "the layers are locked for a reason". From then on, i opted not to. if there's any "unlocking" to be done, i left that decision to the user.
Cheers my friend
hmsilva
Message 7 of 11 (559 Views)
02-14-2013 03:37 AM in reply to: pbejse
I think that is a very valid opinion, and possibly, the correct way of looking at the situation of being in a locked layer.
Cheers
Kent1Cooper
Message 8 of 11 (544 Views)
02-14-2013 04:44 AM in reply to: aqdam1978
aqdam1978 wrote:
.... how can I delete a/all block with specific name in current drawing?
Searching the Discussion Group is always a good start.  This has come up before, for instance.
Kent Cooper
aqdam1978
Message 9 of 11 (513 Views)
02-15-2013 07:23 AM in reply to: pbejse
As usual, your code is the best!
Abbas
pbejse
Message 10 of 11 (492 Views)
02-16-2013 03:10 AM in reply to: aqdam1978
Abbas
You are welcome . Thank you for your kind words :smileyhappy:
The nice thing about the routine is you can modfiy  that for other entity types. by adding conditions and additional arguments.
Glad i could help
You are not logged in.
Ask the Community
