Active Member
nn.araujo
Message 1 of 4 (615 Views)
Delete folder command
615 Views, 3 Replies
01-07-2011 10:59 AM
Hi everybody
I need to delete a folder (not empty) in my LISP routine and I’m not being able to do so. I created the folder using (vl-mkdir “foldername”) but I don’t find the equivalent command to remove it. Any help?
Nuno
Valued Contributor
JustoAg
Message 2 of 4 (606 Views)
Re: Delete folder command
01-07-2011 12:22 PM in reply to: nn.araujo
This delete the folder and its content:
(setq FSO (vlax-create-object "Scripting.FileSystemObject"))
(vlax-invoke FSO "DeleteFolder" "D:\\folder1\\folder2\\Prog\\AutoLISP\\deletme" :vlax-true)
at the end release the FSO:
(vlax-release-object FSO)
Hope this helps.
Justo Aguiar.
Active Member
nn.araujo
Message 3 of 4 (587 Views)
01-09-2011 02:51 AM in reply to: nn.araujo
Hello Just Aguiar,
It works perfectly. I just change from absolute path to local path (vlax-invoke FSO "DeleteFolder" ".\\foldername" :vlax-true). Problem solved!
Nuno
Valued Contributor
anovelli
Message 4 of 4 (410 Views)
03-29-2011 12:35 PM in reply to: nn.araujo
Any way to use a while card?
I want to delete all the Background Plot folders.
For me they are created in C:\Temp\BGPlot_2552 but the number varies.
Please let me know.
You are not logged in.
Ask the Community
