Visual LISP, AutoLISP and General Customization
Delete everything within or outside of a boundary?
15 REPLIES 15
Message 1 of 16
ArchD
17670 Views, 15 Replies
Does anyone have a way to delete everything in or outside of a boundary? I was thinking something like an xclip for normal objects. Right now I use extrim, but that only trims whats touching the boundary line and I would like for it to get rid of everything inside or outside of the boundary. No wipeouts either, not what I'm looking for.
Thanks in advance everyone.
Archie Dodge
Applications Expert - Infrastructure Solutions Division
IMAGINiT Technologies
15 REPLIES 15
Message 2 of 16
in reply to: ArchD
Make a Selection with CP or WP after recovering the
boundary's coordinates (better use a polyline) and then erase the
Selection, in order to remove everything inside the boundary or
use
Select->All->Remove->Selection, in
order to delete everything outside the boundary.
HTH
Humans are born with a wide
horizon.
As time goes by, the horizon narrows and
narrows, until it
becomes a point of view.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Does
either, not what I'm looking for. Thanks in advance
everyone.
Message 3 of 16
in reply to: ArchD
(DEFUN C:ERASEOUT ()
(COMMAND "ZOOM"
"E")
(SETVAR "HIGHLIGHT" 0)
(PRINC "\nTHIS COMMAND ERASES EVERYTHING
OUTSIDE A WINDOW\n")
(PRINC "\nPICK FIRST THEN SECOND POINT OF
WINDOW")
(SETQ PT1 (GETPOINT))
(SETQ PT2 (GETCORNER PT1))
(SETQ OBJS
(SSGET "C" PT1 PT2))
(SETQ W1 (GETVAR "EXTMIN"))
(SETQ W2 (GETVAR
"EXTMAX"))
(COMMAND "ERASE" "C" W1 W2 "R" OBJS "")
(PRINC)
(SETVAR
"HIGHLIGHT" 1)
Does
everyone.
Message 4 of 16
in reply to: ArchD
Here's a simplified version of the same, using the "All" option in object selection:
(PRINC "\nTHIS COMMAND ERASES EVERYTHING OUTSIDE A WINDOW\n")
(command "_.erase" "_all" "_remove" "_crossing" pause pause "")
(SETVAR "HIGHLIGHT" 1)
(PRINC)
That avoids the need to Zoom to the extents so it will "see" everything, because "All" doesn't care
whether things are visible in the current view, the way "Window" and "Crossing" do. And the
crossing-window option in Erase will supply its own prompts about selecting the corners. No
variables required.
Kent Cooper
"andrew" wrote...
(COMMAND "ZOOM" "E")
(PRINC "\nPICK FIRST THEN SECOND POINT OF WINDOW")
(SETQ OBJS (SSGET "C" PT1 PT2))
(SETQ W2 (GETVAR "EXTMAX"))
(PRINC)
Message 5 of 16
in reply to: ArchD
Try this called CookieCutter2. It's similar to extrim with the option you asked for,
delete all inside or outside. Read the header comments for more info.
Joe Burke
Message 6 of 16
in reply to: ArchD
Hi Joe
Its working fine, Thanks for your post.
with regards
P Rajkumar
Message 7 of 16
in reply to: ArchD
You're welcome.
Message 8 of 16
ArchD
in reply to: ArchD
I couldn't ask for more. The description in the header is nice too, thank you very much.
Archie Dodge
Message 9 of 16
in reply to: ArchD
You're welcome.
I spent a lot of time on that routine.
Joe Burke
Message 10 of 16
hamid.akbari
this lisp works just for one object.
if I want to select multiple object to erase other objects ,what should I do?
Message 11 of 16
Will.neal
This is awesome! Thanks!
Message 12 of 16
3dcat
Hi Joe,
I downloaded the CookieCutter2 lsp routine - works great! Thanks for posting it : )
Message 13 of 16
JamaL9722060
Thank you very much Joe Burke for sharing the lsp file. This is amazing
Jamal Numan
Message 14 of 16
steve_davidson
that is the goods, thanks so much for sharing.
Message 15 of 16
Eden.Barrera
I see I'm a little late to the party but it might help someone.
I was able to use what you gave and modify it to have it without having to pick a window. This works if you use limits for your drawings as I do.
For this to work you need to make sure limits are ON.
Also, the proper limits are set for your choice of the border.
(COMMAND "ZOOM"
"E")
(setq pt1 (getvar 'limmin)
        pt2 (getvar 'limmax))
(SETQ OBJS
(SETQ W2 (GETVAR
"EXTMAX"))
(PRINC)
(SETVAR
"HIGHLIGHT" 1)
Message 16 of 16
mc5fan
in reply to: Eden.Barrera
Thank you. I wrote a lsp-scr combo, using your code as a basis, that just made my job much easier!
Lee M.
”Boost
