style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<archd> a écrit dans le message de news:Does
href="mailto:6138719@discussion.autodesk.com">6138719@discussion.autodesk.com...
anyone have a way to delete everything in or outside of a boundary? I was
thinking something like an xclip for normal objects. Right now I use extrim,
but that only trims whats touching the boundary line and I would like for it
to get rid of everything inside or outside of the boundary. No wipeouts
either, not what I'm looking for. Thanks in advance
everyone.
<archd> wrote in messageDoes
href="news:6138719@discussion.autodesk.com">news:6138719@discussion.autodesk.com...
everyone.
this lisp works just for one object.
if I want to select multiple object to erase other objects ,what should I do?
Thank you very much Joe Burke for sharing the lsp file. This is amazing
I see I'm a little late to the party but it might help someone.
I was able to use what you gave and modify it to have it without having to pick a window. This works if you use limits for your drawings as I do.
For this to work you need to make sure limits are ON.
Also, the proper limits are set for your choice of the border.
Thank you. I wrote a lsp-scr combo, using your code as a basis, that just made my job much easier!
