Visual LISP, AutoLISP and General Customization
Debugging my Lisp
7 REPLIES 7
Message 1 of 8
CAD_user85
646 Views, 7 Replies
Debugging my Lisp
Dear Autocad / Lisp users,
Could somebody please help me with my lisp.
The main goal for the lisp is to correct all colors of the given layers.
And for a few exceptions I want to change the LineType and set them to ByLayer.
It works, most of the time. But it always gives errors.
Couls somebody please have a look?
(defun c:SLC8 ()
	(setq kleur 8)
	(ChangeLayerColor kleur)
(defun ChangeLayerColor (kleur / sset ename i)
	(vl-load-com)
	(setq i 0)
	(setq sset (ssget "X" '((8 . "AL*"))))
		(if sset
			(repeat (sslength sset)
				(setq ename (ssname sset i))
				(setq i (1+ i))
				(vla-put-color (vlax-ename->vla-object ename) kleur)
	(setvar "cmdecho" 0)
	(command "-layer" "unlock" "*" "")
	(command "layer" "c" "7" "0" "")
	(command "layer" "c" "7" "*AL70----*" "")
	(command "layer" "c" "1" "*AL-----_VLOERPLAAT" "")
	(command "layer" "c" "2" "*AL-----_SPARING" "")
	(command "layer" "c" "1" "*AL_MAATVOERING" "")
	(command "layer" "c" "8" "*AL31----*" "")
	(command "layer" "c" "8" "*AL32----*" "")
	(command "layer" "c" "8" "*AL21----*" "")
	(command "layer" "c" "8" "*AL22----*" "")
	(command "layer" "c" "8" "*AL_31----*" "")
	(command "layer" "c" "8" "*AL_32----*" "")
	(command "layer" "c" "8" "*AL_21----*" "")
	(command "layer" "c" "8" "*AL_22----*" "")
	(command "layer" "c" "8" "*AT$1A---_TEKST012" "")
	(command "layer" "c" "8" "*AT$1A---_TEKST018" "")
	(command "layer" "c" "8" "*AT$1A---_TEKST025" "")
	(command "layer" "c" "8" "*AT$1A---_TEKST035" "")
	(command "layer" "c" "8" "*AT$1A---_TEKST050" "")
	(command "layer" "c" "8" "*AT$1A---_TEKST070" "")
	(command "layer" "c" "8" "*AT$1A---_TEKST100" "")
	(command "layer" "c" "1" "ATT012*" "")
	(command "layer" "c" "1" "ATT018*" "")
	(command "layer" "c" "2" "ATT025*" "")
	(command "layer" "c" "3" "ATT035*" "")
	(command "layer" "c" "4" "ATT050*" "")
	(command "layer" "c" "5" "ATT070*" "")
	(command "layer" "c" "6" "ATT100*" "")
	(command "layer" "c" "254" "00ATT018*" "")
	(command "layer" "c" "254" "00ATT025*" "")
	(command "layer" "c" "254" "00ATT035*" "")
	(command "layer" "c" "254" "00ATT050*" "")
	(command "layer" "c" "254" "00ATT070*" "")
	(command "layer" "c" "254" "00ATT100*" "")
	(command "layer" "c" "254" "00KAD018*" "")
	(command "layer" "c" "254" "00KAD025*" "")
	(command "layer" "c" "254" "00KAD035*" "")
	(command "layer" "c" "254" "00KAD050*" "")
	(command "layer" "c" "254" "00KAD070*" "")
	(command "layer" "c" "254" "00KAD100*" "")
	(command "layer" "c" "254" "*BL$2----*" "")
	(command "layer" "c" "1" "*BL$3----*" "")
	(command "layer" "c" "254" "*BL$4----*" "")
	(command "layer" "c" "254" "*BL$5----*" "")
	(command "layer" "c" "254" "*BL$6----*" "")
	(command "layer" "c" "8" "*BL$7----*" "")
	(command "layer" "c" "8" "*BM$7----*" "")
	(command "layer" "c" "7" "*BL$9----*" "")
	(command "layer" "c" "7" "*FL80----" "")
	(command "layer" "c" "8" "*WL905---*" "")
	(command "layer" "c" "8" "*Xref*" "")
	(command "layer" "c" "8" "*BL$8----_TEKST*" "")
	(command "layer" "c" "8" "*BT$8----*" "")
	(command "SETBYLAYERMODE" "1" "")
	(command "clayer" "0")
	(command "SETBYLAYERMODE" "99" "")
	(command "layer" "c" "8" "*BL$7----*" "Ltype" "DASHDOT" "*BL$7----*" "")
	(command "._setbylayer" (ssget "X" (list (cons 8 "*BL$7----*"))) "" "yes" "yes")
	(if (tblsearch "LAYER" "BL$8----")
			(command "layer" "c" "1" "*BL$8----*" "Plot" "No" "BL$8----*" "" "")
	(princ "\nLaag BL$8---- Niet kunnen vinden")
	(princ)
	(if (tblsearch "LAYER" "BL$8----Verdieping")
			(command "layer" "c" "1" "*BL$8----Verdieping*" "Plot" "No" "*BL$8----Verdieping*" "" "")
	(princ "\nLaag BL$8----Verdieping Niet kunnen vinden")
	(princ)
	(if (tblsearch "LAYER" "FL------_BWS30")
		(progn
			(command "._setbylayer" (ssget "X" (list (cons 8 "FL------_BWS30"))) "" "yes" "yes" "")
			(command "layer" "c" "14" "*FL------_BWS30" "")
			(command "_draworder" (ssget "X" (list (cons 8 "FL------_BWS30"))) "" "Front" "")
		(princ "\nLaag FL------_BWS30 Niet kunnen vinden")
	(princ)
	(if (tblsearch "LAYER" "FL------_BWS60")
		(progn
			(command "._setbylayer" (ssget "X" (list (cons 8 "FL------_BWS60"))) "" "yes" "yes" "")
			(command "layer" "c" "90" "*FL------_BWS60" "")
			(command "_draworder" (ssget "X" (list (cons 8 "FL------_BWS60"))) "" "Front" "")
		(princ "\nLaag FL------_BWS60 Niet kunnen vinden")
	(princ)
(princ)
Any help will be great.
Thanks in advance.
Michel
7 REPLIES 7
Message 2 of 8
hmsilva
in reply to: CAD_user85
Michel,
some of the things I saw in your code:
(defun c:SLC8 ()
	(setq kleur 8)
;)<--You are close the "SLC8" function in
	(vl-load-com)
	(setq i 0)
(princ)
);<--should be here
you should test the existence of layer before using the command layer, because there are no layer with that name will give some error
you are using several "princ \ n" without any need, you can just use "prompt \ n".
(if (tblsearch "LAYER" "BL$8----");<--You are testing the existence of a ayer with this exact name
    (command "_.layer" "c" "1" "*BL$8----*" "Plot" "No" "BL$8----*" "" "");<--and change "*BL$8----*" and "BL$8----*" , they exist???
    (prompt "\nLaag BL$8---- Niet kunnen vinden")
Hope that helps, good luck
Henrique
Message 3 of 8
hmsilva
Michel,
I made some changes in your code, test the attached code, and see if it gives error
Henrique
Message 4 of 8
CAD_user85
in reply to: hmsilva
Dear Henrique,
Thank you verry, verry much for your help.
I'll give the "updated" lisp a go and let you know.
Greets,
Michel
Message 5 of 8
CAD_user85
Dear Henrique,
I've tested the lisp you provided.
Unfortunaly is doesn't correct all the layer colors, like I want it to do.
No matter tho. I can use the lisp to update my lisp annyway.
I'll might even learn a thing or 2..3.. or even more 😄
Thank you verry much for your help.
Greets,
Michel
Message 6 of 8
hmsilva
You're welcome, Michel
Glad I could help
Henrique
Message 7 of 8
Kent1Cooper
(command "layer" "c" "7" "0" "") ....;;;; 52 similar lines ....
(command "layer" "c" "8" "*BT$8----*" "") ....
For the color assignment part, people who didn't originally learn to work with Layers by the Command:-line Layer command may not be aware of some of its operational possibilities.  You can combine multiple Layer options within one Layer command.  And you can assign most Layer options, such as Color, to more than one Layer at a time, using comma-separated Layer names.  And in Layer options like that, if a stated Layer name doesn't exist, a message will go by that it didn't find it, and it will return to the Layer sub-prompt, but it won't cause any error, which means it's not necessary to check whether a Layer exists as hmsilva's routine does -- if it exists, it will get the color assigned to it, but if it doesn't, it won't matter.  And as to AutoLISP, you can combine multiple commands within one (command) function, but since you can combine multiple Layer options in one Layer command, that becomes irrelevant to this part of the routine.
The unlocking of all Layers and the 54 Layer-color assignment lines can be combined into one (command) function containing one Layer command, containing just one Color option for every color used, rather than a separate (command) function and Layer command and Color option for every Layer name category.  Hoping that my copying and pasting of Layer name categories and deletions of excess stuff are done correctly throughout, this should do it:
(command "_.layer"
  "unlock" "*"
  "c" "7" "0,*AL70----*,*BL$9----*.*FL80----"
  "c" "1" "*AL-----_VLOERPLAAT,*AL_MAATVOERING,ATT012*,ATT018*,*BL$3----*"
  "c" "2" "*AL-----_SPARING,ATT025*"
  "c" "8" "*AL31----*,*AL32----*,*AL21----*,*AL22----*,*AL_31----*,*AL_32----*,*AL_21----*,*AL_22----*,*AT$1A---_TEKST012,*AT$1A---_TEKST018,*AT$1A---_TEKST025,*AT$1A---_TEKST035,*AT$1A---_TEKST050,*AT$1A---_TEKST070,*AT$1A---_TEKST100,*BL$7----*,*BM$7----*,*WL905---*,*Xref*,*BL$8----_TEKST*,*BT$8----*"
  "c" "3" "ATT035*"
  "c" "4" "ATT050*"
  "c" "5" "ATT070*"
  "c" "6" "ATT100*"
  "c" "254" "00ATT018*,00ATT025*,00ATT035*,00ATT050*,00ATT070*,00ATT100*,00KAD018*,00KAD025*,00KAD035*,00KAD050*,00KAD070*,00KAD100*,*BL$2----*,*BL$4----*,*BL$5----*,*BL$6----*"
  "" ; finish Layer command
); end command function
And I wonder whether you could go even further.  If there are no Layers outside the coverage of the routine that start with *AL3... or *AL2... or *AT$1A... but that you do not want to have color 8 assigned to them, and if there are none that start with 00... but that you do not want to have color 254 assigned to them, then you can simplify it to this:
(command "_.layer"
  "unlock" "*"
  "c" "8" "*AL3*,*AL2*,*AT$1A*,*BL$7----*,*BM$7----*,*WL905---*,*Xref*,*BL$8----_TEKST*,*BT$8----*"
  "c" "3" "ATT035*"
  "c" "4" "ATT050*"
  "c" "5" "ATT070*"
  "c" "6" "ATT100*"
  "c" "254" "00*,*BL$2----*,*BL$4----*,*BL$5----*,*BL$6----*"
Similarly, you can assign the same Plot status to multiple Layers at once, and you don't need to check whether they exist in the drawing to do it.  I'll leave you to do such further consolidations.
Kent Cooper, AIA
Message 8 of 8
hmsilva
in reply to: Kent1Cooper
Kent1Cooper wrote:
people who didn't originally learn to work with Layers by the Command:-line Layer command may not be...
Kent,
oops, my bad, is not my case...
I started working with the ACr10, with the firts pull-down menus, almost always used the command line versions of the commands,
so I was obliged to remember that the -layer command can be combined into one (command) function, without giving error...
Thank you for this fix, that will force me to correct a code that I had done, and I will make this code much lighter.
Hopefully I will not forget ... Smiley Wink
Cheers
Henrique
”Boost
