Visual LISP, AutoLISP and General Customization
DXF Group Codes
4 REPLIES 4
400 Views, 4 Replies
DXF Group Codes
Where can I find a listing of all the current dxf group codes and their
explanation that are used in A2K. I've looked in the manuals and also in the
on-line help in A2k searching for dxf and also group codes and I haven't
found what I'm needing. I looking specifically for the group code
information for a MTEXT object.
Brent
4 REPLIES 4
Jason.Piercey
Should be in the Entities section of the DXF Reference.
The DXf appendix are no longer a part of the customsation manual
but can be found as a set of HTML files or a WinHelp file.
http://www.autodesk.com/techpubs/autocad/dxf/dxf2000hlp.exe
http://www.autodesk.com/techpubs/autocad/dxf/dxf2000htm.zip
Good luck,
/Henrik Andersen
"Brent B." skrev i meddelandet
news:D277EA8050B488880BFF9E7970866937@in.WebX.maYIadrTaRb...
the
> Thanks,
> Brent
Brent,
For an object, MTEXT or line, or...
Draw this object in AutoCAD an type
Command : (entget(car(entsel))), and click your object, so you can read the
DXF codes
Bernard
ATC
45700 Villemandeur
France
Brent B. a écrit dans le message :
the
> Thanks,
> Brent
It is not found in the normal AutoCAD help. You must use the Visual LISP
Help Reference. Do this:
1. Type VLISP at the command prompt.
2. Pull down the HELP menu.
3. Select Visual LISP Help Topics.
4. Double-Click DXF Refence.
5. Double-Click ENTITIES Section.
6. Double-Click MTEXT.
... and there you have it!
Daniel J. Altamura, R.A.
Altamura Architectural Consulting
and SoftWorx, Autodesk Registered Developer
DAltamura@compuserve.com
"Brent B." wrote in message
the
> Thanks,
> Brent
”Boost
