I want to create a simple macro (user button in user toolbar in CUI):
If nothing is selected, ask user to select and perform action (scale x2).
If something is selected, perform action (scale x2).
In otherwords, check Pickfirst selection set. But I can't get it to work.
$(if,$(=,1,0),T,F) would return F, so I tried
...$(if,$(=,$(ssget,"_I"),nil...
But that's not correct.
How would I use DIESEL in a macro to use the pickfirst selection set, or if that is nil/empty, ask the user to select objects?
Thank you.
(I hope this is the correct forum for this question.)
Solved by christopher.l.evans. Go to Solution.
(setq ss (if (= nil (cadr (ssgetfirst))) (ssget) (cadr (ssgetfirst)) ) )
selection set now stored in variable "ss"
write your balance code in lisp file and then load the lisp file in the button's macro using
(load "c:\\your_lisp_file.lsp")
This is what I am using. I don't to write directly in DIESEL
@aliensinearth wrote:(setq ss (if (= nil (cadr (ssgetfirst))) (ssget) (cadr (ssgetfirst)) ) )
The above could be written as:
(setq ss (cond ((cadr (ssgetfirst))) ((ssget))))
@aliensinearth wrote:You are brilliant Lee_Mac.
That is very kind of you aliensinearth, thanks
That is a nice solution. However, I was curious if it could be done in a macro with DIESEL.
Ty for your reply.
@Ertqwa wrote:That is a nice solution. However, I was curious if it could be done in a macro with DIESEL.
I very much doubt that it would be possible using DIESEL, as DIESEL has a very limited set of functions.
Is there a specific reason it must be in diesel? If you look at the scale command while you're in cui it shows
$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_scale,^C^C_scale)
maybe that will give you a starting point.
Alternatively you could just create a new toolbar, make a button for it and add a new command with the following macro and it will do what I believe you're asking with something selected or not. It pauses for user input for base point.
^C^Cscale \ \2;
Only thing is that it's not in diesel.
