- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
DELETE DIMENSIONS INSIDE BLOCKS
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi all,
I need a lisp routine which will delete all the dimensions inside selected block or blocks, including nested blocks inside.
Can anybody help please?
Thanx...
Re: DELETE DIMENSIONS INSIDE BLOCKS
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Today is your lucky day..
on my way to overcoming my fear of recursive programming, earlier
I happen to be playing around on a code for eradicating unwanted entities oinside a block
I tweaked it a lttle to fit your neeeds
;; Credit to Jummy BergMark ;;
;; For DeleteObjectFromBlock Routine ;;
;; Manusoft for the Recursive Routine ;;
;; Me for tweaking it for you ;;
(defun C:FXB (/ ELST ENAM ESEL BNAM FLST)
(vl-load-com)
(setq Dsdwg (vla-get-activedocument (vlax-get-acad-object)))
(setq ESEL (entsel "\nSelect block: ")
ENAM (car ESEL)
ELST (entget ENAM)
BNAM (cdr (assoc 2 ELST))
FLST nil
(fix1 BNAM)
(vl-cmdf "regen")
(prin1)
(defun FIX1 (BNAM / BENAM)
(if (not (member BNAM FLST))
(progn
(setq FLST (cons BNAM FLST)
BENAM (tblobjname "block" BNAM)
(while (setq BENAM (entnext BENAM))
;(print (entget BENAM))
(if (= (cdr (assoc 0 (entget BENAM))) "INSERT")
(fix1 (cdr (assoc 2 (entget BENAM))))
(if (= (cdr (assoc 0 (entget BENAM))) "DIMENSION")
(progn
(setq Dim2Del (vlax-ename->vla-object BENAM)
blk (vla-ObjectIdToObject
Dsdwg
(vla-get-ownerID Dim2Del)
(vla-delete Dim2Del)
(vla-get-count blk)
(princ)
)Hope this helps
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi again,
Really my lucky day!
thank you for your help.
Great work ![]()
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
that is cool. thanks for sharing! ![]()
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
There is another way to eliminate the dimensions without selecting the block?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
My version with multiple selection set .....
(defun c:Test (/ ss i sn name lst)
(vl-load-com)
;;; ------ Tharwat 15. June. 2012 ----- ;;;
;;; codes to delete all dimensions entities in the ;;;
;;; selected blocks ;;;
(if (not acdoc)
(setq acdoc (vla-get-activedocument (vlax-get-acad-object)))
(if (setq ss (ssget "_:L" '((0 . "INSERT"))))
(repeat (setq i (sslength ss))
(setq sn (ssname ss (setq i (1- i))))
(if (not (member (setq name (cdr (assoc 2 (entget sn)))) lst))
(progn
(setq lst (cons name lst))
(vlax-for each (vla-item (vla-get-blocks acdoc) name)
(if (eq (vla-get-objectname each) "AcDbRotatedDimension")
(vla-delete each))
(princ)
(if ss (vla-regen acdoc AcAllviewports))
(princ)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The code I'm looking for is more complex.
I need to remove all types of dimensions including the angular dimensions and aligned dimensions, without selecting the blocks.
Also, the dimensions in nested blocks have to be deleted.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
not sure what you mean by without selecting blocks.
If it means you want to remove dimensions from
all defined blocks, you could try:
(defun c:blitz-all-dims ( / tbl ent dlist)
(while (setq tbl (tblnext "BLOCK" (not tbl)))
(if (and
(not (assoc 1 tbl))
(setq ent (cdr (assoc -2 tbl)))
(while ent
(if (= (cdr (assoc 0 (entget ent))) "DIMENSION")
(setq dlist (cons ent dlist))
(setq ent (entnext ent))
(foreach n dlist (vla-delete (vlax-ename->vla-object n)))
(princ)
Ian
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Another
(defun c:blitz2 (/ aDoc)
(vl-load-com)
(setq aDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
(vlax-for blk (vla-get-blocks aDoc)
(if
(and
(eq :vlax-false (vla-get-isXref blk))
(eq :vlax-false (vla-get-isLayout blk))
(not (wcmatch (vla-get-name blk) "`*D*"))
(vlax-for dim blk
(if (wcmatch
(vla-get-ObjectName dim)
"AcDb*Dimension")
(vla-delete dim))
(vla-regen aDoc acAllViewports)
(princ)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
