DCL not closing
4 REPLIES 4
412 Views, 4 Replies
DCL not closing
I just can't figure this one out. Small little routine to calculate the total run of a PLINE (not complete, just starting it out) but from the dialog box, I want "CONTINUE" and "END" buttons. Continue will prompt user to select another 2 points to add. Original dialog box won't close to allow user input. What the heck am I not doing correct?
DCL:
TD : dialog {label = "Total Distance";
  :edit_box  {label = "Total distance: ";
              key = "DISTANCE";}
  :boxed_column {label = "Continue to add? ";
    :row {
      :button {label = "Continue";
               key = "CONTINUE";
               allow_accept = true;}
      :button {label = "End";
               is_cancel = true;}
LSP:
(defun C:TD ()
  (setvar "CMDECHO" 0)
  (setq C-LAYER (getvar "CLAYER"))
  (defun PLINE-GEN ()
    (setvar "ORTHOMODE" 1)
    (setq PT1 (getpoint "\nSelect first point: "))
    (setq PT2 (getpoint PT1 "\nSelect second point: "))
    (command "PLINE" PT1 PT2 "")
  (defun ADD-LINE ()
    (unload_dialog dcl_id)
    (done_dialog)
    (term_dialog)
    (alert "Here we go again...")
    (setq PT3 (getpoint PT2 "\nSelect second point: "))
    (command "PLINE" PT2 PT3 "")
    (DIA)
  (defun DIA ()
    (setq dcl_id (load_dialog "TD"))
    (if (not (new_dialog "TD" dcl_id))(EXIT))
    (progn
      (action_tile "CONTINUE" "(done_dialog)(ADD-LINE)")
      (if (= DIST-NUM nil)(set_tile "DISTANCE" "0")(set_tile "DISTANCE" DIST-NUM))
      (mode_tile "accept" 2)
      (start_dialog)
  (PLINE-GEN)
  (DIA)
  (setvar "CMDECHO" 1)
  (PRINC)
Any help is GREATLY appreciated...
4 REPLIES 4
pbejse
Not sure why you used edit box for "DISTANCE" if the purpose is only to show the Total length, but i guess you know what you're doing.
(defun C:TD ( / Dist-num GoTo)
  (defun PLINE-GEN ()
  (defun ADD-LINE ()
    (setq DIST-NUM (+ DIST-NUM (distance pt2 pt3)))
    (setq pt2 pt3 GoTo nil)
    (DIA)
  (defun DIA ()
(progn
        (set_tile "DISTANCE" (rtos DIST-NUM 2 2))
      (action_tile "CONTINUE" "(setq Goto T)(done_dialog 1)")
      (action_tile "End" "(done_dialog 0)")
      (start_dialog)
    (if GoTo (ADD-LINE))
  (PLINE-GEN)
  (setq DIST-NUM (distance pt1 pt2))
  (DIA)
  (PRINC)
HTH
Welcome to the forum  tcarbone.
_Tharwat
in reply to: pbejse
The use of system variable osmode must be used side by side with the command call that
askes for getting points .Smiley Wink
in reply to: pbejse
Perfect... thanks so much!!!
pbejse
You are welcome tcarbone. And welcome to the forum Smiley Happy
”Boost
