DCL lisp Routine
7 REPLIES 7
Message 1 of 8
823 Views, 7 Replies
DCL lisp Routine
Can anyone help?  I have the following:
(defun RSplot (Title$ Question$ / Answer$ Dcl_Id% Return#)
  (princ "\nRSPlot")(princ)
  (vl-load-com)
  (setq Dcl_Id% (load_dialog "RSPlot.dcl"))
  (new_dialog "RSPlot" Dcl_Id%)
  (set_tile "Title" Title$)
  (set_tile "Text1" Question$)
  (action_tile "Freeze" "(done_dialog)(command ".layer" "_freeze" (strcat "KS-JK-Sig")"))
  (action_tile "Thaw" "(done_dialog 0)(command ".layer" "_thaw" (strcat "KS-JK-Sig")"))
  (setq Return# (start_dialog))
  (unload_dialog Dcl_Id%)
  (if (= Return# 1)
    (setq Answer$ "Freeze")
    (setq Answer$ "Thaw")
  Answer$
);defun RSPlot
(princ)
Now for the DCL file:
RSPlot : dialog {
  key = "Title";
  label = "";//Title$ from lsp file
  spacer;
  : text {
    key = "Text1";
    label = "";//Question$ from lsp file
    width = 35.0;
    alignment = centered;
  spacer;
  : row {
    fixed_width = true;
    : button {
      key = "Freeze";
      label = "&Freeze";
      width = 7.92;
      fixed_width = true;
    : button {
      key = "Thaw";
      label = "&Thaw";
      is_default = true;
      width = 7.92;
      fixed_width = true;
}//RSPlot
I get the miplaced dot on input message.  Any suggestions?
Rich Scampoli
7 REPLIES 7
Message 2 of 8
pbejse
Questiion for you,
why  (strcat "KS-JK-Sig")
Not sure if this is want you want to achieve , i would have done it this way.
  (vl-load-com)
  (action_tile "Freeze" "(done_dialog 1)(setq  Answer$ \"Frozen\")")
  (action_tile "Thaw" "(done_dialog 1)(setq Answer$ \"Thawed\")")
  (start_dialog)
  (if (= Answer$ "Frozen")
     (command ".layer" "_freeze" "KS-JK-Sig" "")
  	(command ".layer" "_thaw" "KS-JK-Sig" ""))
    (princ (strcat "\nLayer KS-JK-Sig"  Answer$))(princ)
 Hope this helps
Message 3 of 8
If you use the VLIDE to write your code you'd see the error straight away. Also, when you load the code and get the ";error: misplaced dot on input" message, if you double-click that message it will take you to the error in the code. Very nifty.
Anyroad, you're trying to put quotes inside quotes which you cannae do. You'll need something like:
(action_tile "Freeze" "(done_dialog)(command \".layer\" \"_freeze\" (strcat \"KS-JK-Sig\")")
S
Message 4 of 8
in reply to: pbejse
pbejse,
Thank you so much.  That worked perfectly.  I am very new to lisp writing lisp.  I have to do more research on Visual lisp to help me, etc. but this gives me a great launching pad.  I cannot thank you enough.
Rich Scampoli
Message 5 of 8
Scott,
Thank you.   That is great to know.  As I said, I am very new to lisp so I hadn't realized my mistakes.
Rich Scampoli
Message 6 of 8
andrew.nao
look into using open dcl much easier
Message 7 of 8
in reply to: pbejse
Now another question, if I may.  I cannot seem to get this to work with my reactor:
(setq plot_rctr
(vlr-command-reactor nil '((:vlr-commandWillStart . StartPlot))))
(defun StartPlot (calling-reactor endcommandInfo / thecommandstart)
   (setq thecommandStart (nth 0 endcommandInfo))
    (if (= thecommandStart "PLOT")(RSPlot "Layer: KS-JK-Sig" "What would you like to do?")
Any ideas?
Message 8 of 8
andrew.nao
im not that up on the reactors and since no where is the variable plot_rctr used in your code you posted
i would say
change this line
(setq plot_rctr
to
here is my reactor for saving on close maybe it will help ya
[code]
(setq App      (vlax-Get-Acad-Object)
      Doc      (vla-Get-ActiveDocument App)
      DwgProps (vla-Get-SummaryInfo Doc)
(setq Num (vla-NumCustomInfo DwgProps)) ;gets number of custom fields
(defun DoBeforeSave(/)
(vlr-command-reactor nil '((:vlr-commandWillStart . DoMyStuff)))
(princ)
(defun DoMyStuff (reactor params)
(if (= (strcase (car params)) "SAVEAS")
(progn
;;==============do stuff here
(if (> num 0)
(progn
         (vla-put-keywords dwgprops "")
         (vla-put-subject dwgprops "")
         (vla-put-Title dwgprops "")
         (vla-put-comments dwgprops "")
         (vla-put-author dwgprops "")
            (repeat num
                (vla-GetCustomByIndex DwgProps 0 'id 'value)
                   (if (vl-catch-all-apply
                'vla-removecustombykey
               (list dwgprops id)
                     (vla-addcustominfo dwgprops id "")
                   ) ;if
            ) ;repeat
[/code]
”Boost
